Help Car won't start
Hey guys,
92 Integra
I just replaced my icm and ignition coil. The car wasn't starting and it seem to do the trick for 2 days... now this afternoon, it just dies while driving (once again) It did however restart a few minutes later but a little ways down the road it died again and now won't start. I have changed most everything including the main relay a couple years back along with the timing belt. New starter. I'm lost because I don't understand why it would run fine right afterwords and now the same problem is back..
Anyone have similar issues resolved?
Thanks
92 Integra
Thanks
Re: Help Car won't start
Hey guys,
92 Integra
Thanks
92 Integra
Thanks
Have u checked fuel pressure? Could b Fuel filter needs replacing, fuel injectors clogged, fuel pump goin bad. First check fuel pressure to make sure u getting fuel
Yeah had similar problem. I changed my spark plugs, then it ran fine, then it happened again, then changed my cap and rotor, ran fine after that.
I believe it could be the cap and rotor, because when you take out the Coil And ICM you have to take off the cap and rotor, so after that it ran fine because you moved it around.
90crxdriver
04-17-2008 05:12 AM
