car rpm on D really low
97 honda accord lx
automatic
iddle is perfect on P, but once i put the car on D, iddle drops really low feels like it is about to die?? what can be the cause and what are the things i have to look at??
thanks for the help in advance
automatic
What is the rpm with the trans in gear?
Does it stutter at all or just a really low rpm?
Is this new? If so was there recent work done?
If old, has the car ever stalled?
Verify the base ignition timing is correct. Warm up the engine. Turn it off, jumper two wire blue connector. Connect timing light to battery/#1 spark plug. Turn engine on with no accersories on, no radio/vent/lights/etc. Base timing should be on the Red/Yellow mark with the front pulley and timing pointer, not white mark.
If the paint is worn off, the red/yellow mark for base timing will have three grooves/notches, TDC mark will only be a single groove/notch.
IIRC 96/97 does not have provisions for adjusting timing if it is off. Then you may need to check the camshaft timing belt is correctly set.
A dirty IACV may cause a low idle. Setting Base Idle
Verify that everything is in working order prior to readjusting the idle speed. Worn/dirty plugs/wires/cap/rotor may cause a low idle from weak spark.
sounds like weak ignition like you mentioned. sounds like the same symptoms my buddy's old escort had when it was running on 2 cyl. damn long *** 3 speed auto, and 2 cylinders firing, it took literally 30 seconds to hit sixty at WOT
jodyboy
27
Apr 21, 2014 05:52 PM
stevn
Nov 20, 2008 12:06 PM
type Gendy
May 14, 2008 12:29 PM
hondapwr
Jan 13, 2006 06:58 AM
