how to install clutch without alignment tool
Old Oct 29, 2002 | 12:50 AM
rasta420's Avatar
Default how to install clutch without alignment tool
dont have the alignment tool to install clutch on a 88 civic dx hatch. how would i go about putting the clutch on? is there any way to do this without the tool?
thanks
Old Oct 29, 2002 | 01:40 AM
jc836's Avatar
Default Re: how to install clutch without alignment tool (rasta420)
Your new clutch may come with the tool. Some do. Meantime-it is NOT a good idea to do a clutch without some sort of pilot tool. If you can find an old input shaft for your model tranny-that would be the best way, otherwise rent the tool.
Old Oct 29, 2002 | 01:52 AM
boostinb18's Avatar
Default Re: how to install clutch without alignment tool (jc836)
ok.... the way ive done it is get a long 3/8" drive extension and put some electric tape on it and use that........ and just to let you know IF THE TRANNY GOES ON.... IT IS PROPERLY ALLIGNED! so if it bolts up your all good! good luck!
Old Oct 29, 2002 | 04:20 AM
wronghand's Avatar
Default Re: how to install clutch without alignment tool (boostinb18)
You can pick up the alignment tool at any auto parts place for about 2 dollars. Just get one and make the job easier.
Old Oct 29, 2002 | 04:51 AM
Tbone's Avatar
Done it this way about 5 times, works like a charm You can also get a generic adjustable alignment tool for like 14.00 at most local pep boy's/napa/autozone type stores if you dont like the tape idea.
Old Oct 29, 2002 | 07:25 AM
Chris's Avatar
Default Re: how to install clutch without alignment tool (wronghand)
Old Oct 29, 2002 | 07:28 AM
USDM 4G VTEC's Avatar
i have gone to 3 ******* auto parts and none of them carries ******* clutch alignment tools... anyways u can still use a long extension with a 3/8 unsiversal joint on the tip.. that its basically as tick as the shaft... and shuold put it right close to where it should be.. when u insert the tranny it will aling itself..
Old Oct 29, 2002 | 07:58 AM
ScottEK's Avatar
Default Re: how to install clutch without alignment tool (JDM EF9)
Most places carry a universal one, I tried doing it without any tool just by eye and ruined the splines on one clutch, luckily I had another laying around but otherwise I'd be screwed. Invest the $15-20 in the tool.
Old Oct 29, 2002 | 08:08 AM
cyberx's Avatar
Default Re: how to install clutch without alignment tool (beta13)
well the thing is these parts stores are stupid, its not an alignment tool its called a Pilot tool or something with pilot, i went to one parts store and they knew what it was, and the other i was lookin at the screen while they were doing it and they were like we dont have it, and i was like its the pilot tool, and it actually was.... their not very intelligent at some of these auto parts stores.....
Old Oct 29, 2002 | 11:10 AM
Hcivic88's Avatar
Default Re: how to install clutch without alignment tool (cyberx)
ive seen it done many times without a tool, but i figured it was worth it to buy the tool, so i just invested my $15canadian towards a tool, its gotten its money worth, all my friends bring their cars to my house when they need to install a new clutch now, lol
Old Oct 29, 2002 | 02:18 PM
cbrman's Avatar
Default Re: how to install clutch without alignment tool (Hcivic88)
Just an fyi, the alignment tool that comes with most aftermarket kits does not fit. I ended up buying one for a ford pinto to install mine.
I took the old clutch and bearing to the parts store and they checked all the ones for the hondas, and they even pulled the complete clutch kit and the one in it did not fit my clutch or the new one in the box.
Pinto's rule
Old Oct 29, 2002 | 05:25 PM
ThatRicerDaniel's Avatar
Default Re: how to install clutch without alignment tool (cbrman)
this is cake .. just put the clutch and flywheel and everything on.. but dont tighten it all the way.. then get it to where it looks centered .. then slide the tranny on all the way. the get a long extension with your 12 point and ratchet and and tighten the bolts through where the starter goes. when its time for the next bolt just spin the pulley on the other side of the motor back and forth to where you need it. it works ! good luck.
Old Oct 29, 2002 | 06:04 PM
carsaregood's Avatar
Default Re: how to install clutch without alignment tool (NitrousDreamz)
i have tried lots and lots of auto parts stores with no luck as well. i've eyeballed it once, and i guess i was lucky enough for it to have worked. I've since picked up the universal/adjustable one, that works just fine.
tacchan
26
Mar 17, 2010 11:25 AM
RTW DC2R
Feb 11, 2005 04:37 PM
bp_viper
Apr 26, 2004 09:51 PM
steve_s
Apr 20, 2003 05:06 PM
Red_Si
11
Nov 2, 2002 11:43 AM
