Transmission & Drivetrain Gearboxes, Differentials, Clutches
shifter not going side to side *cables good*
Old Feb 15, 2014 | 02:48 AM
Dalamar's Avatar
Default shifter not going side to side *cables good*
It's a m2b4, I pulled the cable off the trans and it moves freely, but the lever on the trans doesn't, time for a new trans or what should i look at?
Old Feb 15, 2014 | 04:33 PM
Emeraldbomber's Avatar
The levers won't move at all? Not even of you manually grab them and try it?
Old Feb 15, 2014 | 07:59 PM
viper_boy403's Avatar
Default Re: shifter not going side to side *cables good*
the shifter mechanism cover is removable, take it off and I'm sure the issue will be apparent
Old Feb 16, 2014 | 02:28 AM
Dalamar's Avatar
popped the cover off , moved fine, reinstalled, goes through all the gears and then gets stuck in reverse.
Thanks for your help
mikenichol123
Dec 14, 2017 03:14 PM
neonkid
Honda Civic (2006 - 2015)
Mar 7, 2014 05:57 PM
FGtwo
Mar 9, 2011 06:16 PM
slitterman
11
Feb 28, 2010 11:20 AM
CivicSwapper
25
Feb 4, 2009 06:47 PM
