94 integra RS won't crank
Old Feb 15, 2014 | 02:20 AM
bike123's Avatar
Default 94 integra RS won't crank
The car was running fine . I changed the starter and main relay . Still the car will not turn over . What else should I change ? Will a bad ECU or distributor cause a no crank issue ? where is the clutch kill switch ? I was thinking of replacing that and the Ignition Switch. Will check all the fuses in the morning .
Old Feb 15, 2014 | 07:59 AM
Eg.ls.turbo's Avatar
Default Re: 94 integra RS won't crank
Have u jumped the starter to the battery to see if it'll turn over?
Connect one long wire from starter ( the small ground wire from the starter ) to directly to the positive terminal on the battery. If this doesn't turn over ur motor then might b ur ignition switch, if it does turn over then its ur starter switch underneath ur clutch pedal.
It could also b ur ground wires loose or broken somewhere. Check the ground wires on the thermostat housing ( should b 4 wires with a screw ) make sure it's contacting. Other ground is grounded from top of tranny to the chassis, make sure that's grounded.
Also check for dead battery
Old Feb 16, 2014 | 06:00 AM
bike123's Avatar
Ok will do, and thank you for all the info .
Old Feb 16, 2014 | 06:51 AM
fcm's Avatar
fcm
Old Fart
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
s.langley
Feb 3, 2019 06:31 AM
deucedeuceEK
Jul 21, 2015 10:32 AM
rogue420
17
Dec 17, 2013 11:10 AM
wesk18
Dec 6, 2010 11:06 PM
stl eh2
Dec 3, 2009 10:07 AM
