Help Car won't start
Old Feb 14, 2014 | 07:24 PM
Kasten's Avatar
Default Help Car won't start
Hey guys,
92 Integra
I just replaced my icm and ignition coil. The car wasn't starting and it seem to do the trick for 2 days... now this afternoon, it just dies while driving (once again) It did however restart a few minutes later but a little ways down the road it died again and now won't start. I have changed most everything including the main relay a couple years back along with the timing belt. New starter. I'm lost because I don't understand why it would run fine right afterwords and now the same problem is back..
Anyone have similar issues resolved?
Thanks
Old Feb 15, 2014 | 08:06 AM
Eg.ls.turbo's Avatar
Default Re: Help Car won't start
Originally Posted by Kasten
Hey guys,
92 Integra
Thanks
Does it sound like it's bogging?
Have u checked fuel pressure? Could b Fuel filter needs replacing, fuel injectors clogged, fuel pump goin bad. First check fuel pressure to make sure u getting fuel
Old Feb 15, 2014 | 06:24 PM
ramboPandA's Avatar
Yeah had similar problem. I changed my spark plugs, then it ran fine, then it happened again, then changed my cap and rotor, ran fine after that.
I believe it could be the cap and rotor, because when you take out the Coil And ICM you have to take off the cap and rotor, so after that it ran fine because you moved it around.
Old Feb 16, 2014 | 02:20 PM
ramboPandA's Avatar
U fix it?
Old Feb 16, 2014 | 11:06 PM
nicknack25's Avatar
I've read it can be from fuel pump, main relay, fuel filter, or ignition switch..
91rexhf
10
Dec 27, 2008 05:06 PM
90crxdriver
Apr 17, 2008 05:12 AM
dragaholic
Aug 17, 2007 11:05 AM
pu5sipoppr
Jul 30, 2005 01:21 AM
94_CRVtec
Apr 23, 2005 10:26 AM
