Hard to shift gears
Old Feb 14, 2014 | 12:36 PM
dragonkx's Avatar
Default Hard to shift gears
my 96 civic dx, manual transmission. I am starting to have trouble shifting gears, I have to force it in or its hard. I think the clutch is gone. it was changed like 5 years ago. last I experience this was on a 99 civic si, and it was the clutch. I was able to shift smoothly when engine was off, but when I turned it on shifting gears was hard. any ideas?
Old Feb 14, 2014 | 12:49 PM
Former User's Avatar
Default Re: Hard to shift gears
Spongy pedal, fluid loss, pedal height adjusted properly?
ej1b18c1's Avatar
Your pilot bearing is most likely the reason for this. Get a clutch kit.
NotARaCist's Avatar
I never narc'd on nobody!
Your pressure plate may not be fully disengaging. Start off by adjusting your clutch pedal play (buy/borrow/download a factory service manual for a how-to), and bleed your clutch line. It uses standard Honda brake fluid, and all brake fluids deteriorate over time.
Old Feb 14, 2014 | 01:02 PM
96ek.ninja's Avatar
Check the hydraulic fluid level, also check master and slave clutch cylinders to make sure that they aren't leaking.
Mrabourque
Transmission & Drivetrain
Mar 3, 2015 04:34 PM
snzh22
Jul 19, 2008 04:09 PM
deeweezy187
Feb 26, 2008 01:20 PM
lilliewillie
Dec 12, 2005 05:35 AM
B18CR-X
Sep 22, 2003 11:49 AM
