1991 Honda Accord Ex Wagon Check engine and acceleration problems
Old Feb 14, 2014 | 09:31 AM
1991wagonEX's Avatar
Default 1991 Honda Accord Ex Wagon Check engine and acceleration problems
Hey all, I have a 91 accord ex wagon, and recently a radiator hose burst, it was one going from the block to a valve into the firewall (for the heater core, im assuming) anyways, i replaced it right away and refilled the coolant. When i started it right afterwards, my check engine light came on every second or third time i started it, so i put more coolant in, and that solved the problem of it coming on right away. Now it only comes on once i hit 60-70mph, and every once in a while my car will feel like its about to stall and i lose power and start slowing down as i accelerate. Im pretty lost on what this could be. My best guess is the MAP sensor? Not sure why my radiator hose going out would suddenly affect that, but anyways, does anyone have any ideas as to what it could be? Or any experience with this problem? Sorry about the long post, but i figure the more details the better. Thanks for any help.
-Edit- Its the 2.2 4speed automatic, and It idles fine and normal when im sitting.
-91wagon
Old Feb 14, 2014 | 02:48 PM
holmesnmanny's Avatar
pull the code
Old Feb 14, 2014 | 09:40 PM
Default Re: 1991 Honda Accord Ex Wagon Check engine and acceleration problems
How do i do that on a older car? Ive only ever pulled codes off OBDII.
Old Feb 14, 2014 | 10:33 PM
you jumper the service connector with a paperclip and count the blinks...go to youtube and search for "how to retrieve check engine codes honda" then google "honda obd1 codes"
Old Feb 15, 2014 | 04:20 AM
HondaPartsHero's Avatar
Technical Hero
http://www.justanswer.com/honda/18tn...da-accord.html
Old Feb 15, 2014 | 09:42 PM
Thanks for the help guys, I'll give it a try tomorrow.
Old Feb 18, 2014 | 12:16 PM
So it came up as 2 slow blinks and 3 quick ones, which i think is the code for the knock sensor, which is something ive never even heard of, does anyone have any idea where its located?
azack_J
Nov 6, 2015 04:38 PM
Valvador
Honda Civic (2001 - 2005)
17
Aug 25, 2011 02:00 PM
Mo0m0oSaZn
Jan 20, 2011 04:04 PM
dark378
Oct 13, 2009 07:41 PM
chiaxi2002
Feb 12, 2009 01:45 PM
