2000 civic si b16a2 issue
Old Feb 13, 2014 | 05:49 PM
wanabecurry's Avatar
Default 2000 civic si b16a2 issue
hey guys just literally made this page today because i always come to this site when i encounter problems with my car but this one is more serious than usual. Car was running with low oil and i've never hit red line at 8000rpms but all of sudden when i leave for work i hear a knocking sound coming from my engine when car is turned on. Could be a bent piston rod or bent valves.. just looking for suggestions or any ideas, anything helps right now! thank you!
Old Feb 14, 2014 | 05:35 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 2000 civic si b16a2 issue
Most likely you spun a rod bearing. Have fun with the engine rebuild.
Old Feb 14, 2014 | 11:35 AM
have you had to do an engine rebuild yourself?
Old Feb 14, 2014 | 05:25 PM
DO IT ON ALL FOURS
Haha... dozens. If you are asking you would be MUCH better off paying a shop to do it for you.
Old Feb 15, 2014 | 02:49 PM
VegasInvasion's Avatar
I'm Huge In Japan
Just sounds like a spun bearing, worst case you may have scarred the crank if you drove on it for too long.
A monkey can rebuild an engine, it's not rocket science if you know how to use tools.
Set aside a weekend, take your time, and follow the repair manual.
Don't skip ANY steps, and don't cut any corners - new rings, seals and bearings all around.
Should only run you like $300 in parts, and it'll give you a new appreciation for your engine
Old Feb 15, 2014 | 02:50 PM
I'm Huge In Japan
PS why is this in the tuning section?
Old Feb 15, 2014 | 02:51 PM
DO IT ON ALL FOURS
I beg to differ with your comment on "monkey's can build engines". You don't frequent the chassis forums very much and see all the stupidity do you?
Cdude222
Aug 15, 2013 08:23 AM
jaxarmy82
Feb 24, 2012 03:17 PM
98-black-GSR
May 13, 2011 12:55 PM
ccivic
Apr 28, 2006 08:49 PM
Dyzee
10
Apr 28, 2004 11:56 AM
