EG/GSR swap - CEL codes 1, 21, and 43 and running poorly
Old Feb 13, 2014 | 04:31 PM
RoughidleV8's Avatar
Default EG/GSR swap - CEL codes 1, 21, and 43 and running poorly
My EG w/GSR was engine codes 1, 21, and 43. I have double checked all my wiring to the ecu and all the parts came from the same car. Before motor was pulled I heard it run and no CELs I put it in and now I have them. It runs good at WOT and MID but off idle falls on its face. Thanks for the help.
Old Feb 13, 2014 | 04:50 PM
B_Swapped93's Avatar
Default Re: EG GSR PROBLEMS
what year is the engine obd1 also ?
Old Feb 13, 2014 | 07:43 PM
ej1b18c1's Avatar
OP, what ecu, harness, and intake manifold are you running?
Old Feb 16, 2014 | 12:49 PM
1994 stock everything P72 ecu stock single butterfly intake
Old Feb 16, 2014 | 12:57 PM
Former User's Avatar
Default Re: EG/GSR swap - CEL codes 1, 21, and 43 and running poorly
Have you properly reset the ECU to see whether all codes return?
Old Feb 17, 2014 | 12:57 PM
Yes always get 21 43 first time for 1. Mash the throttle and everything's great vtec and all barely ease the throttle misses like crazy
Old Feb 17, 2014 | 02:28 PM
instrument's Avatar
did you wire the vtec sensor? no idea what model civic you have.
you say vtec is great, but it shouldnt be with code 21, might just be mistaking the gsr secondaries with vtec?
have you bothered following the service manual for the engine cels youre getting? if not just dld the manual thats ehat theyre for.
Show15
Aug 7, 2011 07:14 AM
SINBAD
Mar 1, 2010 08:18 PM
Your Name
11
Jan 17, 2010 08:07 PM
99931238
Jun 9, 2004 05:28 PM
dreweg
Aug 2, 2003 08:53 AM
