89 civic hatchback d16z6 swap bogs under acceleration.
Old Feb 13, 2014 | 12:42 PM
normanl2491's Avatar
Default 89 civic hatchback d16z6 swap bogs under acceleration.
89 hatch si with d16z6, p28 ecu, obd1. bought the car and the car would bog at full throttle and up hills ( could barel go passed 65mph). the guy said the car only needed a new tps. got home changed the tps, dizzy cap, plugs and it took like ten minutes to start. then finally wouldn't start. I changed the dizzy and nothing (has spark). I have no clue what it could be, please help.
Old Feb 13, 2014 | 01:05 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 89 civic hatchback d16z6 swap bogs under acceleration.
Did you calibrate your TPS?
Using a voltmeter, connect the NEG probe to chassis ground and the POS probe to the red TPS wire. Rotate the TPS until you get about 0.5volt reading. Tighten the screws and verify that you still have 0.5volts
Are you 100% sure you put the plug wires back on correctly?
Last edited by 4drEF; Feb 20, 2014 at 07:35 AM. Reason: Just realized I wrote VSS instead of TPS
Old Feb 13, 2014 | 06:02 PM
CRXguy_88's Avatar
Any codes?
Old Feb 13, 2014 | 06:19 PM
instrument's Avatar
so this is a no start issue now?
you have spark but do you have fuel?
Old Feb 13, 2014 | 08:56 PM
Glowicki's Avatar
So, this is now a no start issue?
Does the engine turn over?
Does it have compression?
Fuel?
Is the mechanical timing correct?
You said you changed the dizzy, did you put the ignition rotor in the new dizzy correctly?
Old Feb 17, 2014 | 04:16 AM
sorry I haven't replied right away. no I haven't calibrated the tps I need to do that. but the way the guy before set up the old tps is weird, ill have to take a picture and put it on here. there's two tps lol. from the old d16a6 and one on the motor(d16z6). im pretty sure the wires are right I can check again. and my cluster is bad so I don't know if its throwing codes or not. and yes it don't start anymore and I checked one of the spark plugs and it had spark. it has compression. fuel im not positive, I just thought it sounded like a ignition problem. and I haven't checked the mechanical timimg. and the new dizzy came with the rotor aready installed.
Old Feb 17, 2014 | 08:36 PM
sstupid's Avatar
10 Year Member
It sounds like you are having a voltage problem under load. That could be as easy as a bad spark plug wire or as hard as the vehicle speed sensor. You'll have to start narrowing it down. I don't envy you.
Old Feb 18, 2014 | 12:30 PM
will a car start with a bad tps sensor?
Old Feb 18, 2014 | 12:56 PM
would bad grounds do this?
Old Feb 18, 2014 | 06:11 PM
instrument's Avatar
lots of things can cause a car to not start, my car wouldnt start because of a crossed wire on the conversion harness...with no working check engine light what exactly do you think we can tell you?
and how do you have two tps hooked up, that makes absolutely no sense.
from what you described the car was in limp mode, your wiring is f'd up, and you drove the car so long in such bad condition its stopped running.
so either fix the dash and relay the cels to us, or just stop bumping the thread and follow the no start faq. until you have some info to share theres no advice we can give beyond blind guessing.
Old Feb 19, 2014 | 04:12 AM
I only drove the car like 40 miles. I don't think its in limp mode because I had a integra that went into limp mode and its nothing like this. it didn't start until I changed the stuff I said I did. I don't have the car with me right now so I cant upload pictures or work on it I just thought some one else would of had this problem and they could help me alittle bit, sorry.....
Old Feb 19, 2014 | 03:37 PM
HondaPartsHero's Avatar
Technical Hero
Calibrate the TPS
Fix your cluster and post any codes
Old Feb 20, 2014 | 07:08 AM
I still have to find a new cluster but I will calibrate the tps this weekend. and maybe take some pictures.
Old Feb 20, 2014 | 07:38 AM
4drEF's Avatar
Keyboard Humorist
"New cluster" to me sounds like you don't have a cluster at all right now.
You need a cluster to get VSS signal to the ECU unless you converted to a tranny mounted electronic VSS.
The stock speed sensing system has a speed pulser mounted to the back of the cluster. It it turned by the speedo cable and sends the pulses to the ECU just like a tranny mounted VSS would.
Bogging might happen and for certain vtec will never work without VSS.
Old Feb 21, 2014 | 12:31 PM
i have a cluster but the only thing that works is the speedometer.
Kannan08
17
Jan 7, 2013 09:35 PM
ted_dejong
Jun 21, 2009 11:50 PM
Sho Pow
Sep 27, 2004 08:20 PM
