left turning oil pan
yeah im racing on a oval track i wanna get a oil pan that is designed for circle track racing so that the oil stays even in the pan and doesnt all go to one side when i turn
Yes, any b18 pan will bolt up or b16 pan for that matter, but make sure you get the non-vtec b18 pan if you are running the stock b20 sump. The non-vtec and vtec sumps sit at different heights. If I remember correctly, the vtec sumps require a deeper pan.
correct, vtec oil pans are deeper, therefore you can put a gsr/type r/b16 oil pan on an ls/b20 but not vise versa. i HIGHLY reccomend against the moroso, no matter what anyone says it WILL leak. god himself couldn't get a moroso pan to seal!
Lol I've read a lot of horror stories about that. But I've also seen just as many ppl have no issues with it. I personally run a MyHondaHabit.com oil pan gasket along with there stud kit. Not a single drop of oil has leaked out, I only used Honda Bond on the 2 locations required by the tech manual and tighten her down.
