no spark, need help
Hey guys I got a bit of a problem... first thing I had was an h23a1 dizzy to h23v everything pluged up fine got no spark.. checked all my grounds fuel pump intake.. still nothing.. tried to do the internal coil dizzy instead of external, got power on internal coils but I still had to plug in external coil. But still no spark also got a new icm. Any one have any ideas?
Im ob1 right now external coil got a p13 ecu... checked all my grounds and still have the original dis with external coil but still no spark i get two clicks is that maybe the problem.. or what it can be... how i can check. If the ecu is working
If your car is originally a 92 then get a hold of a td61u distributor and you should be good to go. Obviously you will need to wire in vtec if you haven't yet. Just treat the h23a vtec block like an obd1 h22a1.
hondachris1994
Aug 15, 2017 10:58 AM
s2kkk
20
Apr 15, 2004 11:12 AM
