VTEC pressure switch
Old Feb 11, 2014 | 05:41 AM
mikeljcarr's Avatar
Icon2 VTEC pressure switch
Sorry if this is a newb question, but when it comes to this, I'm pretty much a newb .
I am putting a B16B into a 94 Delsol. I've been reading up on wiring the VTEC and have and only see where I have the VTEC solenoid. I don't see a pressure switch on the engine. Am I missing something or does this engine type not need the pressure switch?
One other question: there was one additional sensor connection on the intake manifold of the stock engine that I don't have on the B16B. It was toward the top / rear on the driver's side. Is this not needed for this engine? Do I need to modify anything with the ECU or wiring?
Old Feb 11, 2014 | 05:59 AM
carlos8's Avatar
Default Re: VTEC pressure switch
JDM engines don't have pressure switch, you need to bypass it.
Here we go!!
http://www.phearable.net/tech/wiring/vtpsbypass.gif
Old Feb 11, 2014 | 06:21 AM
mikeljcarr's Avatar
Thanks Carlos. any idea what the other sensor I referenced is?
Old Feb 11, 2014 | 06:41 AM
carlos8's Avatar
Pretty sure you talking about the IAT, yes it's necessary.
This is?
https://encrypted-tbn2.gstatic.com/i...fAS2lQZUgqwO9Z
This is the b16b manifold
https://encrypted-tbn0.gstatic.com/i...sBz4lVVj9rgFqA
Old Feb 11, 2014 | 06:52 AM
mikeljcarr's Avatar
That's not the sensor I was referring to, although I know what that one is for now
The sensor I am asking about was located right above that one on the delsol manifold. It's a black device mounted on the manifold. I have a picture, but I can't figure out how to get it uploaded on here. I could email it to you (or anyone for that matter) if it would be helpful.
Old Feb 11, 2014 | 07:18 AM
kyden's Avatar
evap purge? you won't need it if you're running obd1. you can hook it up if you want.
Old Feb 11, 2014 | 07:23 AM
carlos8's Avatar
Receive your photo, ^^ as kyden said Evap. Purge valve.
Old Feb 11, 2014 | 07:27 AM
mikeljcarr's Avatar
So, do I just leave it unplugged or do i need to do anything electrically with the plug? Thanks again for all the help!
And if I abandon it is there anything else that I can remove in the bay to clean it up?
Old Feb 11, 2014 | 03:05 PM
apexi_rsx's Avatar
depend on if ur running a jdm ecu then yes it will work... if u are running a usdm ecu then no u will throw a pressure switch code and vtec will not engage....
Old Feb 11, 2014 | 03:34 PM
mikeljcarr's Avatar
I'm using the US ECU, but am sending it off to be chipped / base mapped at phearable. Would they be able do what's necessary to make the ECU not throw the code?
Old Feb 11, 2014 | 06:48 PM
ej1b18c1's Avatar
Yes, they will ask you when you fill out your set-up for your base map.
Delphince
Engine Management and Tuning
23
Jun 8, 2018 05:18 AM
EG type GTR
56
Oct 25, 2015 07:29 PM
Travis R
11
Jul 23, 2011 06:04 PM
Dj Skidz7
Oct 29, 2006 10:21 PM
95accordh22a
Mar 27, 2005 06:39 PM
