eChanged my piston rings
Old Oct 28, 2002 | 09:14 PM
petrv's Avatar
Default Changed my piston rings
I have changed my piston rings - should I now go carrefully for some first kilometers or can I go hard from the first kilometer?
[Modified by petrv, 6:14 AM 10/29/2002]
Old Oct 28, 2002 | 09:26 PM
kinesistech's Avatar
Default Re: Changed my piston rings (petrv)
You'll find some mixed answers here about this. Some people say just go like hell, most say take it easy for 1000 miles so I guess you can go 1609.334 km if you'd like. My thinking lies somewhere in between.
Old Oct 28, 2002 | 09:36 PM
sweet's Avatar
Default Re: Changed my piston rings (kinesistech)
though thoughts will vary, i say go for at least 500 miles before really whooping on it and taking it to redline often. i did almost 1,000 miles before really beating on the motor.
lots of stop and go, up and down miles are needed to break it in properly and quickly. letting the motor idle between 2500 and 3000 rpm for about 20-30 minutes after replacing the rings is good to help seat them, then change the oil to get rid of debris.
Old Oct 28, 2002 | 09:41 PM
petrv's Avatar
Default Re: Changed my piston rings (sweet)
Someone told me to go 1000km very carrefully, then change the oil and go other 1000km carrefuly, then I can go hard. After that firts 1000km, I will change to some racing oil 10W60 (blended).
Old Oct 28, 2002 | 10:29 PM
HotWheelz's Avatar
it's more for the rings to seat right.... i've noticed after we rebuilded a GSR that in the first couple hundred clicks it would smoke a bit if you went to 6000.. but after about 1000km it would stop.... so I think this would be a good idea to break in..to prevent scorring or potential cylinder wall problems down the road.
Old Oct 29, 2002 | 07:39 AM
civicsitek GanGsTa's Avatar
Default Re: Changed my piston rings (HotWheelz-turboh22dx)
Opinions, I agree are wide spread on this topic. My experiences tell me to change the oil after the initial 2500 rpm for 20-30 minute routine, then drive low rpm, heavy load, ie uphill conditions for a bit, then downhill for a while. Varying driving conditions is the best way to break rings in. After a few hundred miles change the oil again and you are good to go. I still wouldn't redline it at this point but thats just me, just should be ok to do so if you have to.
benjoh
Oct 30, 2017 02:08 PM
all-mtr-teg
Mar 4, 2007 04:19 PM
douglas_be
Mar 29, 2004 01:31 PM
RedRacerCivic
Dec 2, 2003 10:36 PM
zer0zer0 TypeR
Sep 4, 2003 11:35 AM
