Skunk 2 throttle body idle problem
Old Feb 9, 2014 | 04:50 PM
lukasmccracken's Avatar
Default Skunk 2 throttle body idle problem
Hey, so I have a skunk2 throttle body and Intake manifold. I am having idle problems though. When I first start the car I have to coax the car to stay on until it is warmed up. If I don't keep my foot on the gas it will idle really low then die.
I have:
changed iacv
rehooked up pcv
adjusted tps
checked for vaccuum leaks
I don't know what else to check for or if this is a design issue with all skunk2 thottle bodies? Any tips or help is appreciated
Old Feb 9, 2014 | 05:23 PM
B_Swapped93's Avatar
Default Re: Skunk 2 throttle body idle problem
adjust the rotor(throttle plate) stop screw gsr or itr ? if you have a gsr the throttle cable and bracket need to be changed.
Old Feb 9, 2014 | 07:02 PM
I have the itr cable and bracket already but isnt it that the throttle plate should be closed all the way when at idle? since heat makes the metal expand and makes the idle eradic?
Old Feb 9, 2014 | 08:12 PM
No it's supposed to sit open ever so slightly so the plate doesn't feel like it's touching the bore the you make the last adjustments via the idle screw. it doesn't get close to warm let alone hot enough to make it expand...
finding that right point is hard and will require you play around with it I hated setting it
Old Feb 9, 2014 | 10:06 PM
So I just need to make it sit very slightly open then? I should warm up my car first or just do it then see if my car starts and idles by itself?
Old Feb 9, 2014 | 10:18 PM
Yah like I said it's a pain in the *** to get it right, shoot for an idle of 800-850rpm max. I have mine at 1.2K one but I'm using a 74mm with the ultra series street manifold and pro1 cams.
Old Feb 10, 2014 | 12:00 AM
yeah I usually set my idle to about 900 just because I like it that way, I have a 70 mm with the same manifold and type r cams, thank you for the help I will get it tomorrow!!
mgags7
Jan 30, 2025 08:58 AM
elnegro
Sep 13, 2018 06:35 PM
Na99Si
Apr 3, 2003 02:59 PM
Shft@9GSR
Nov 15, 2002 11:21 AM
dplatt
Jul 14, 2002 09:00 AM
