Hasport EFDHC Troubles
Well guys, here's the deal. I've been lurking around HT for quite a few years now, picking up tons of useful information, but I'm having an issue with my Hasport EFDHC kit.
For starters, I'm putting a b7 and hydro trans into my 91 STD hatch. All other engine mounts line up and are bolted in except for the very rear mount. I thought that with the new bracket Hasport supplies, I wouldn't have to change the rear mount, but I could be wrong.
Long story short, I'm just trying to figure out if anyone else has had this issue, and what I need to do. Any help is appreciated. I attached a picture to hopefully help show what I'm talking about. Don't mind the janky polyurethane "solid mount" failed attempt the previous owner made. -___-
Thanks guys.
Thanks guys.
Did you slide the mount over to the right? There are 2 sets of holes that are for the rear mount, both d series cable mounts use both rear holes. The auto mount uses the front left and the manual uses the front right. It looks like you may need to slide the mount to the right side mounting holes.
I haven't moved the mount, I'll give that a try when I get home from work. Thanks for the responses fellas. I guess that's what I get for buying the kit second hand.... no instructions. Appreciate it!
1SlowSi
Nov 1, 2008 05:42 AM
