Honda snap ring tool to replace the lower ball joint boot
Old Feb 9, 2014 | 11:37 AM
JohnnyEF's Avatar
Default Honda snap ring tool to replace the lower ball joint boot
Trying to save some money and wanted to know if there is an aftermarket equivalent to the Honda snap ring tool used to replace the lower ball joint boot on civic EG. The part number I am referring to is 07965-SA50500. Thanks
Old Feb 9, 2014 | 12:15 PM
nub's Avatar
nub
Default Re: Honda snap ring tool
I don't remember any special tool needed. The ring for the boot is like a big thin key ring, it just rolls in place. The snap ring for the ball joint to lower control arm is a standard snap ring.
Old Feb 9, 2014 | 12:29 PM
98civdx's Avatar
Master Detailer
You don't need the Honda tool. a good pair of snap ring pliers will do just fine.
Old Feb 9, 2014 | 01:36 PM
94EG8's Avatar
Seagull Management
There's no special tool needed. To remove the spring clip that holds the ball joint off simply use your hands and a flat screwdriver, the same goes for installation.
Old Feb 9, 2014 | 09:31 PM
JohnnyEF's Avatar
Thank you for your input fellas
hi ho silver
Nov 3, 2010 05:11 AM
Hala
Aug 8, 2009 10:31 PM
D16SohcVtec
14
Apr 12, 2009 09:23 AM
customx_
Jan 18, 2002 06:33 AM
