Honda OBD II Transmission PIDs
Old Feb 9, 2014 | 09:41 AM
andyz's Avatar
Default Honda OBD II Transmission PIDs
2000 Accord 90k miles no mods, F23A1, MAXA
Pulled codes and found a likely ancient P1739, Third Clutch Pressure Switch.
OBD II scanner software reports there is Freeze Frame data to go with...
I use a serial port software to get any PID I want. like this.
ATI
"ELM 327"
010C
"BUS INIT...DONE, 01 0C 0C 78"
When I ask for Mode 2 PID, 020C, result is No Data.
What possible PIDs is Honda recording in freeze frame for a P1739?
Old Feb 9, 2014 | 02:44 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Honda OBD II Transmission PIDs
I'm guessing it is just merely saving the point in memory for future reference.
What exactly it is saving may be just the pressure 3rd clutches pressure sensor registered value at the time that caused the code to be set.
But the PID may not be fully supported on the ECM, or with your scanner, and may require the appropriate Honda scanner to register/calculate its true value.
Is the 3rd clutch switch a variable resistor, or simply an switch? If it is a switch then there probably is no data other than the switch was turned on/off and the code was set.
Old Feb 9, 2014 | 09:18 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
ATI
"ELM 327"
010C
Ayntime a DTC is set,it is mandatory for the PCM to store the data parameters as they are, at the time of the fault. These parameters are simply the basic OBD 2 generic data PIDS. They are unlikely to be of any use for the P1739....
Old Feb 10, 2014 | 08:35 AM
andyz's Avatar
Allright, so the future reference, I had it backwards.
The commands to retrieve freeze frame are formatted thusly:
Mode, PID, Frame#
020c00
Not
Mode, Frame, PID
Frame number is always zero I think.
Now, What would cause my Third Clutch Pressure Switch to have some detectable problem at:
2393 RPM
70 KM/H
29 % Throttle Position
84 deg Celcius (slightly under full operating temp)
STFT and LTFT similar to idle conditions
IAT 85 deg Celcius
What shall I do? Clear the code and the freeze frame now and see if it comes back?
Old Feb 10, 2014 | 11:58 AM
MAD_MIKE's Avatar
MM Gruppe B
Check that the fluid level is full.
Check that the sensor is not loose/leaking/broken connection/wire.
IIRC on 98-02 ATs that sensor is known to fail.
Old Feb 14, 2014 | 11:03 AM
andyz's Avatar
Fluid level is perfect. Overall inspection gives absolutely no indication of broken, loose, leaking sensor connections, gaskets.
Cleared code. Drive a few miles , highway, and local roads, code doesn't come back.
What's up with that? Is that pressure sensor just flaky? Is it failing slowly? OR, it there some other, hydraulic circuit, clogged filter, etc, problem, that is known to show up as Third CLutch PRessure sensor failure?
Old Feb 15, 2014 | 12:48 AM
MAD_MIKE's Avatar
MM Gruppe B
If the code happened when you did not own the car, PO may have done something. May have driven it low on fluid, may have had an intermittent connection, may just be the sensor is flaky/failing/voodoo.
Maintain the transmission and it should be fine, until it isn't.
Old Feb 15, 2014 | 09:38 AM
andyz's Avatar
http://www.hondapartsnow.com/diagram...oid-456565.png
#12 and #13
Which one is 2nd, which one is 3rd?
12 28600-P6H-003 SWITCH ASSY., OIL PRESSURE JPN, USA 1 $77.08 $55.50
13 28600-P7Z-003 SWITCH ASSY., OIL PRESSURE (TEXAS INSTRUMENTS) JPN, USA 1 $72.02 $51.85
What's the PSI on these?
http://www.napaonline.com/Catalog/Ca...692_0353956308
IMPORTANT INFO: 33 PSI Black Connector
http://www.napaonline.com/Catalog/Ca...691_0353956310
IMPORTANT INFO: 38 PSI Green Connector
So, what is what here?
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
gjvanl
Nov 23, 2014 04:22 PM
N1civicSi
Oct 13, 2013 04:45 PM
andhoova
Aug 31, 2010 07:13 AM
tdog1
Transmission & Drivetrain
Nov 23, 2008 07:38 PM
