Replacing Engine, need a little advice
Old Feb 8, 2014 | 05:06 PM
That1guyinvegas's Avatar
Default Replacing Engine, need a little advice
Ok, so I am going to put in a new D-series engine, with MPFI, My current engine is a ZC SOHC Non-Vtec, with lots of small issues, and only DPFI, and its just more time effective to get a JDM motor, I just want to know what motor people think is best, I currently have a 4 speed tranny, but I have a 5 speed to put in as well as I will be getting new axles. and do I just need to wire in the new injectors properly to a PM6 ECU? I know the PM5 wont run MPFI, would I need anything special if I went with say a DOHC? possibly VTEC?
Any and all halp would be appreciated.
Old Feb 8, 2014 | 05:21 PM
F22Master's Avatar
Default Re: Replacing Engine, need a little advice
Just google DPFI to MPFI swap. Its been covered a million times.
Old Feb 8, 2014 | 05:55 PM
I know how to do that, the help I wanted was on picking an engine, weather or not I need a specific D-series engine, or will any D-series, SOHC or DOHC, VTEC or Non-VTEC, as long as its MPFI work?
Old Feb 8, 2014 | 08:08 PM
F22Master's Avatar
Once you convert to MPFI, any 4 injector engine will work. You just have to match the ECU to the distributor (OBD-0 ECU = OBD-0 dizzy, OBD-1 ECU = OBD-1 OR 2 dizzy) and use the proper O2 sensor (OBD-0 = 1 wire O2, OBD-1 = 4 wire O2). And if you want to convert to OBD-1, then you need an OBD-0 to OBD-1 adapter harness.
But yes, any d series will physically bolt in.
Old Feb 8, 2014 | 08:17 PM
instrument's Avatar
you can put a v6 in your crx, either ask more specific questions or everyones going to tell you to search.
Old Feb 8, 2014 | 08:37 PM
Thank you, it is OBD-0 and I'm hoping to keep it that way, I have a set of headers and a new cat & catback, because my exhaust system is practically just missing, arriving soon next week, So is the PM6 the proper ECU for an
OBD-0 MPFI? (Single wire O2 sensor, as well as brand new OBD-0 Dizzy)
Old Feb 9, 2014 | 06:42 AM
ProjetEF's Avatar
yes PM6 is right
Aar0n
Nov 29, 2014 02:02 AM
HVN
May 13, 2010 12:40 PM
Bambii_X
May 2, 2010 07:31 PM
FourthGenHatch
30
Jul 5, 2002 03:11 PM
96civic-vti
May 13, 2002 05:55 AM
