1990 honda civic hazards work but nothing else will
Old Feb 8, 2014 | 05:00 PM
mattchew_2124's Avatar
Icon2 1990 honda civic hazards work but nothing else will
Car was running fine one day the next it wouldn't start brought battery in and got it checked, cleaned terminals and wiring to battery, hazards work and nothing else will turn on. seatbelts are automatic and won't even move
Please help
Old Feb 9, 2014 | 06:23 AM
ProjetEF's Avatar
Default Re: 1990 honda civic hazards work but nothing else will
can it be ignition switch issue ? dose it crank or can you describe it a little more?
hazard is one of the only thing that will work without the key IN, thats why i think it might be your key switch
Old Feb 9, 2014 | 06:52 AM
Former User's Avatar
Sounds like the hood 60A fuse is blown.
Old Feb 9, 2014 | 07:06 AM
no lights come on. i get nothing when i crank key. their is no power to any of the car its not dim its nothing . i am going to check 60 A fuse this afternoon i will let you know. if you need anymore info to try and help let me know i appreciate all the input.
Old Feb 9, 2014 | 05:35 PM
it was 60A fuse under hood thank everyone for input
Old Feb 10, 2014 | 04:20 AM
sstupid's Avatar
10 Year Member
Awesome! Now you just have to figure out why it blew.
Old Feb 12, 2014 | 08:11 PM
romansevo8's Avatar
also the hazards are on a separate relay then everything else. if you pull one of your turn signal bulbs out they are going to blink faster, but if you turn on your hazards they will still blink normal.
Old Feb 12, 2014 | 08:14 PM
None of this^ is correct.
Old Feb 13, 2014 | 10:48 AM
romansevo8's Avatar
what? Some idiot cut off my corner light harnesses of my crx but my hazards still flashed slow, but turn signals would flash fast, why is that?
Old Feb 13, 2014 | 11:06 AM
The hazards and blinkers use the same bulbs and relay.
Old Feb 13, 2014 | 11:23 AM
romansevo8's Avatar
But why does one flash faster then the other??
Old Feb 13, 2014 | 11:24 AM
romansevo8's Avatar
not trying to give you **** just curious.
Old Feb 13, 2014 | 11:34 AM
My speculation:
hazards = 4 bulbs flashing
turn signals = 2 bulbs flashing
When 1 out of 4 hazard bulbs is out, the circuit voltage is 25% higher during each flash cycle.
When 1 out of 2 blinker bulbs is out, the circuit voltage is 50% higher during each flash cycle.
I think the resulting voltage differences lead to different pulse rates for the relay.
NotAJDMFanBoy
Apr 21, 2020 08:21 PM
prodjay10
Honda Civic (2001 - 2005)
Dec 14, 2016 12:12 PM
wpgredteg
30
Oct 18, 2010 11:50 AM
andlude
Dec 25, 2009 02:41 AM
j_kevin_ca
Jun 25, 2007 11:00 AM
