99 j30 4 door accord swapped for j35a4
Old Feb 7, 2014 | 01:37 PM
lsvautocross's Avatar
Default 99 j30 4 door accord swapped for j35a4
Need some help with changing over my 99 Accord with the j30 equipped with the distributor, to a j35A4 with coils. Both automatic
Old Feb 8, 2014 | 05:02 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 99 j30 4 door accord swapped for j35a4
Could you be any more vague.
Simply, get the Engine/Trans/Wire harness/ECU/mounts and anything else that attaches the J35 to its parent car and drag it home. Then place all the bits you need into your '99.
If you think your gonna just bolt the J35 to the glass jaw 4 spd... 'your gonna have a bad day'.
Old Feb 8, 2014 | 12:01 PM
The main question i needed answered was about going from distributor to coils, wasnt sure if it was gonna be as simple as removing the j30 engine harness and computer and replacing with the j35 engine harness and computer. Would the ecu plugs have the same pins from distributor to coils for the cabin harness. The transmission is being replaced with the factory (glass jaw 4 speed) but remanufactured and with a larger transmission cooler, are the bolt patterns the same or are just saying bad day because the autos are all pieces of sh!#.
Ro-sean Cadet
Jan 15, 2016 11:34 AM
amc-89
Mar 8, 2012 05:42 PM
LOKSTER
Mar 4, 2011 11:59 AM
