98 civic SI - Random Misfire issue, where to start?
Old Feb 7, 2014 | 12:09 PM
Chody's Avatar
Default 98 civic SI - Random Misfire issue, where to start?
Hey im pretty new to the electrical side of cars...
I checked the codes and its showing 300,302,304
the list is hyooge as to what could cause the misfire
Description:
Basically when the car is cold it drives perfectly fine, on my way to work after about 20-30 mins if i hit the gas more than say 15% it misfires terribly, shakes like crazy, and i have to basically floor it to accelerate.
I know it could be ECM, injector harness, 02, IAC, EGR, dizzy ECT.
just wondering if anyone has had experience with this and can point me in the right direction. Im a total noob when it comes to volt meters
EDIT holy ***** i forgot to say, its a 98 civic SI (canadian) Mods are crappy intake, headers.
Old Feb 7, 2014 | 12:20 PM
Chody's Avatar
Default Re: Random Misfire issue where to start
i also found this, i dont know why its been done.
looks like a vac line cut, and re routed
Old Feb 11, 2014 | 11:16 AM
Chody's Avatar
any ideas?
Old Feb 11, 2014 | 11:46 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Remove your distributor cap and check for moisture or corrosion. The codes you posted aren't familiar looking codes. Are you sure you're not leaving a digit out?
It's most likely some sort of distrbutor related failure. Igniter, cap, rotor, etc. How do the plugs look?
Old Feb 11, 2014 | 11:55 AM
Former User's Avatar
How old are the spark plugs, plug wires, distributor cap, and rotor? If old, just replace as these components are the most common cause for your CEL codes.
Old Feb 11, 2014 | 02:06 PM
nismoracingsx's Avatar
300= Random Misfire
301-304= Cylinder Misfire
Dunno if you're serious or not since OP obviously just left the P0 off (ie: P0300)
Old Feb 11, 2014 | 03:45 PM
B serious's Avatar
^nope. I was making sure. It could have been an error in typing P1301, etc.
Old Feb 11, 2014 | 09:11 PM
raider1qaz's Avatar
check for wrong gap on sparkplugs,
Old Feb 12, 2014 | 10:23 AM
Chody's Avatar
plugs look good,
the colder it is outside the longer i can drive normally.(-5Celcius i drove 40mins fine)
today was warm so i only got about 15 mins of normal power, then it started to crap out again.
here is the dizzy, it looked corroded but not too bad?
Old Feb 12, 2014 | 10:27 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That red dust I've seen people say is the Red Dust of Death.
I think you may need a new distributor.
Old Feb 12, 2014 | 10:42 AM
Chody's Avatar
fun stuff. just cap n rotor or actual dizzy?
Old Feb 12, 2014 | 11:23 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Full dizzy I believe. I'm assuming the dust is metal dust from the dizzy internals.
Old Feb 12, 2014 | 01:54 PM
Chody's Avatar
yeah i couldnt tell, i youtubed how to change it and it looks simple, im thinking a new one cant hurt.
Old Feb 13, 2014 | 08:15 AM
Chody's Avatar
alrighty, so on my way home i found a new fault
i had suspected a vac line all along. this im hoping kind of narrows it down. except for the fact i have no idea what an evap system is
Chody's Avatar
any ideas on where to start?
Old Feb 13, 2014 | 08:19 AM
Don't lose your focus. You clearly have distributor issues. It's the white elephant in the room.
98civicsc
Jan 28, 2012 06:01 PM
Wrona
Oct 4, 2010 09:28 PM
t0ny
Dec 29, 2009 09:50 AM
banks234
12
Jan 1, 2009 10:11 PM
