autoX suspension for an 01 G-SR
hey guys. so I started getting into the autoX scene and I'm looking around for the best suspension I can buy while also lowering my 01 teg gsr about 2in. anyonehave any suggestions I've found some skunk2's for around 500 bucks but I've seen full coilovers go for over a grand easy anyone running a teg in autoX and if so what suspension are you running??? Post pics of the car if you have em please
From: Pensacola, FL and every Court House in Louisiana
Sticky, FAQ's, and Google does wonders!!! Hell, half the post on this page are asking the "Whats the best suspension" question.
The only name you list are JUNK2 so you obviously have not made an effort to research.
I've seen a lot on koni/gc setups but I was wondering if anyone ran skunks but I suppose that answers my question i see slit more people getting suspensions for daily drives. While my car IS a daily driver I want a track suspension
You want to lower it? Now you're in STC at a minimum, where you'll fight a losing battle against smaller and significantly lighter Civics.
This past weekend there were 4civics running granted only tepid them were built up I'm certain I can take em. But I reallywanna get a lower stance there's too much body roll around the turns and j can't keep my speed up as much as I could if I had a lower center of gravity
let me say it, as some have hinted.
SEAT TIME, is what you are looking for.
once you are able to drive your car to it's max, then, start looking for upgrades.
compare your car to the other cars in your class. once you can beat them by 3secs. then look to upgrade. (this is just my opinion)
As far as recommendations for suspension, the biggest bang for buck setup is the Koni/Ground-Control setup. Under $1k, warranty, will last forever and will do everything you need it to. $500 won't get you any competitive adjustable suspension.
Use Google, it's your friend. Research and understand what you need and more importantly what you don't need. Then research and read some more.
DA_DAvid
Suspension & Brakes
Jun 21, 2008 02:27 PM
