Possible Rod Knock?
I have a 96 civic hatch CX with a b18b1 swap, while driving today I noticed that when i got up to the 20-30mph range the car would make a knocking type noise and also some kind of squeaking. At idle the car sounds perfectly normal, no knocking noise.
I do have a CEL for my TPS, could this have something to do with this issue? Any advice given is greatly appreciated thank you.
Rod knock is very obvious.. You'll hear like a jackhammer beating in the bottom of the block.. Hard to turn over because the loose bearing jammed the crankshaft. Or the yet milder issue is like a loose nut rooling around in the bottom end.
Maybe the term "knock" shouldn't be used in this case then. Because every situation I see with a rod knock, you can hear it when the car is idling. But, mine ONLY happens when I'm driving going about 20-30mph. My exhaust was installed today, i didn't really think anything of it but since this issue is happening after work done on my exhaust I guess it would have to be something involving that.
I will post a vid of the noise tomorrow. Also, when its in neutral and i rev it up it doesnt make the noise. Which is now making me think its not something involving the engine.
The exhaust may wiggle a little more when your accelerate or send vibrations through the pipe, this can cause it to hit or tap against the surronding metal, if its aftermarket or improperly installed, causing a noise. Just a simple thing to check to rule out any small problems exhaust problems. my car has done this a few times.
stupidhard
11
Jun 28, 2014 06:19 PM
underthesun
Apr 29, 2009 04:32 AM
