H22a Headers.
What would be a good header for my h22a? Current one will cause me to fail inspection. Would be nice to have one to fit my engine bay, have correct bolt points as it is swapped into a del sol.
All H headers should bolt up to the engine exactly the same. Some are made with the specific angle needed for an H2B car, if that is what you need, or just a standard H22 header if you are using an H tranny and mounts.
If you just need to pass inspection, any ebay or stock replacement header should work, but may not last long, or give any performance benefit. If you want to spend a little bit and have a decent performing header, a replica header from Logic etc is a decent option, or you can spend a bunch on something like a Hytech, smsp etc.
Michalob234
Jun 30, 2004 12:02 PM
HotWheelz
Nov 2, 2003 03:11 PM
