Help: Install dual gauge pillar pod and oil and water temp
Old Oct 28, 2002 | 07:45 PM
RacerBoy's Avatar
Default Help: Install dual gauge pillar pod and oil and water temp
I'm going to be doing this soon and I just needed some pointers. I need instructions on what kind of lines to run and to where to get these gauges working. I have a mechanical oil pressure and water temp from autometer. I plan on putting them in my A-Pillar gauge pod. Thanks.
Old Oct 28, 2002 | 07:53 PM
MADEINIRAQ's Avatar
Default Re: Help: Install dual gauge pillar pod and oil and water temp (RacerBoy)
i ran my lines throught the grommet where the cruise control wires went through..
if using copper line... don't kink it... actually don't kink any line
for the lights in the guages.. wire them to the connector on the fuse box that is on when the lights are on.. it's towards the top. blade type connector. (i can take a pic if you'd like)
and i think that's it.
oh yeah.. take your stock oil sensor and throw it away. saves you from usin a t
also.. buy the metric thread adapter packet thingy (by sunpro) from autozone. that has the right piece for the oil line so it's the correct thread
Old Oct 29, 2002 | 08:48 AM
keithv's Avatar
Default Re: Help: Install dual gauge pillar pod and oil and water temp (madeiniraq)
i totally agree with this. the block thread type is BSPT and the fittings for the gauges are NPT. so get a BSPT to NPT adapter and you won't have any leaks.
GUILOTINE
Feb 12, 2005 06:52 AM
FlatTire
Jul 1, 2004 03:24 PM
JMD
Apr 22, 2003 11:23 AM
crxhfpower123
Apr 3, 2003 03:58 AM
speedymon
Nov 11, 2001 08:29 PM
