90 civic timing belt issue?
Old Feb 4, 2014 | 04:38 PM
votex5's Avatar
Default 90 civic timing belt issue?
Yesterday while on way to work, my 1990 Honda Civic shutdown on the highway whilst I was doing about 70 mph. There was a pop almost like
a backfire and the car coasted to a stop. I checked for fuel line or pump
leak, none found, have plenty of spark. Starter turns but engine wont
start. Engine has plenty of oil, didn't overheat I got underneath the car
to check for any major leaks or damage none found. I got my 17mm
socket and the engine turns easily. I pulled my distributor cap off and bumped the starter but the rotor goes nowhere. Is this a sign of a sheared
gear on the distributor or possibly the timing belt breaking. Because of my work schedule, I have not yet had the time to pull the cover off or remove the distributor completely to see if the distributor is the problem or if worse the timing belt and or valves are the issue. Any help going forward to guide me to find the problem would be greatly appreciated.
Old Feb 4, 2014 | 04:45 PM
lsvtec hf-er's Avatar
Default Re: 90 civic timing belt issue?
Sounds like a broken belt buddy
Old Feb 4, 2014 | 04:47 PM
Tyson's Avatar
your distributor test confirms the belt is gone.
it happens.
the engine is non interference so 99% the engine is fine. just replace the belt.
and its a good idea to replace the water pump and tensioner, while youre in there but not mandatory.
Old Feb 4, 2014 | 05:11 PM
votex5's Avatar
Thank yo so very much... Will begin the task of replacing belt and water pump as well.
MegaTwinky
Jun 7, 2012 11:44 PM
suje
10
Feb 21, 2012 09:12 AM
pinoyboy204
Mar 2, 2010 06:21 AM
DrewDown
Nov 18, 2004 07:05 PM
Yambor
Jun 23, 2004 08:45 AM
