Door/ignition/headlight reminder (beep) not working on 1995 Accord
I have a 1995 EX coupe and it never beeps at me for anything (could be a blessing) but I'd like to fix it. Any suggestions on how to fix it? I'm guessing it's possibly just a fuse or switch.
it most liking is a fuse possible relay, but I would go through them all checking which it is. the most possible worst it can be is crossed wire, or a ground came loose or corroded.
I don't recall where the warning buzzer is, but if your ignition tumbler/switch was ever repaired/replaced it may be that the wiring for the warning buzzer was never reconnected. Remove the plastic cowling for the steering column and inspect the wiring.
lakerschamp2000
Jan 11, 2010 08:41 AM
jdmep3
Jul 31, 2005 04:30 AM
