s80 tranny in crx?
Old Feb 4, 2014 | 08:26 AM
yarealdad's Avatar
Default s80 tranny in crx?
hi guys..
i wanted to know if a s80 tranny fits in a honda crx 2 gen...
i have the non vtec 124 hp dohc model european version..
would like to know
Old Feb 4, 2014 | 09:04 AM
jlicrx's Avatar
Default Re: s80 tranny in crx?
not without getting different mounts and hydraulic to cable clutch conversion
Old Feb 4, 2014 | 12:55 PM
Creator's Avatar
I believe there may be more to it then that. Isn't that the ZC motor, which I believe is a D series motor. The S80 trans is from a B series. These will not mate without an adapter plate.
Old Feb 5, 2014 | 01:24 AM
yarealdad's Avatar
yeah its the ZC yeah its the d16z5.. ohh.. i forgot.. i will swap b16 or b18 before.. but i still need some mounts right?
Old Feb 5, 2014 | 01:27 AM
yarealdad's Avatar
is the s80 even that good? i know it comes with a LSD which is good for traction... im trying to get ~200 hp NA or i will do a turbo / compressor setup to get ~240 hp...
is there an alternative tranny which i could use ?
i bet the s80 is still the best one isnt it?
Old Feb 5, 2014 | 04:30 AM
Creator's Avatar
I guess it depends on what your going to do with it. I would say 240 is an easier goal for a forced induction engine, while 200 n/a is going to be harder/probably more costly to get to. Not sure about where you are, but as far as an LSD transmissions go the Y80/S80 is one of the easier ones to find. That's all I really have to offer you as I've never driven a B series at those power levels.
jilicrx was right if your swapping in a B series motor. You will need mounts, and the hydro conversion. GL
Old Feb 6, 2014 | 03:45 AM
rd91sib18c5r's Avatar
If your going to be doing a swap anyway you can get a mount kit for hydro or cable trans.
There are some good cable transmissions ys1 can be found with a lsd or you can ad one,
jdm j1 b16 cable tranny came lsd also.
Burgess0909
12
Jan 23, 2007 06:40 PM
drewboy
May 7, 2005 04:18 PM
TegBen
Dec 25, 2003 11:54 PM
Doug684
14
Oct 1, 2003 01:11 PM
It's*BOLO!!
May 10, 2003 02:23 PM
