ECU toasted? fuel pump not priming car not turning on
Old Feb 3, 2014 | 04:29 PM
Evos's Avatar
Default ECU toasted? fuel pump not priming car not turning on
Hello HT, I got a 1995 Acura Integra and yesterday i tried to start my car up and no go... i dident hear the fuel pump priming when i turned the key over so that was an immediate problem. I replaced the Main relay and still nothing. jumped the fuel pump at the main relay and it kicked on so with that still on i tried to turn the car over and nothing... I am running a JDM B18c(R) everything stock for the most part on a chipped p28. I'm thinking that its the ECU i checked the fuse for the ECU under the hood and it looked good even replaced it i believe it its a 15? Before i buy another p28 and get a chip made by xenocron anyone have any other possible ideas? ill post a pic up of the ECU in a bit doesn't look like any capacitors are blown or anything.
Old Feb 3, 2014 | 05:54 PM
Evos's Avatar
Default Re: ECU toasted? fuel pump not priming car not turning on
Old Feb 4, 2014 | 08:59 PM
Evos's Avatar
No one has any thoughts at all on this?
Old Feb 4, 2014 | 10:49 PM
Eg.ls.turbo's Avatar
If I was u, if u have a friend with a Integra obd1 ecu ask to borrow it just to start the car and if it starts then ur ecu is bad. But don't drive on it! Just to start.
Old Feb 4, 2014 | 10:52 PM
Also wanted to add check ur ignition system to see if it's gone bad
Old Feb 5, 2014 | 07:27 AM
fcm's Avatar
fcm
Old Fart
Check for power at the injectors, [wire that is the same color at all 4 injectors].
Check for power at IGP1 and IGP2 at ECU/ECM.
Check for power at distributor assembly.
Check all the above with ign. switch in BOTH the run and start positions. 94
Old Feb 10, 2014 | 06:12 PM
Evos's Avatar
Alrightttttt so got my new chipped p06 from xenocron today ECU was not the problem.... I tried to start my other civic with a b20 swap and i hear the main relay clicked but it also sounds like the ecu is clicking as well is this normal? I got back in my integra and it was not clicking. I really have no fkin idea what is wrong. Im going to try what some of you suggested in the next few days its goign to snow badly these next couple days....
Evos
Engine Management and Tuning
12
Nov 12, 2019 10:57 AM
jdmAccord210
Oct 22, 2013 11:22 AM
Markalark
Sep 22, 2013 03:32 PM
no_rice_please
Oct 12, 2009 09:36 PM
DarkBB4
Sep 13, 2007 04:24 AM
