Custom Carbon fiber 2009 Lexus IS 250 lip
Old Feb 2, 2014 | 03:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Custom Carbon fiber 2009 Lexus IS 250 lip
Whats up honda tech So im bored and wanted to share another carbon fiber project im doing. A guy has a 2009 Lexus IS 250 show car with siebon carbon trunk hood and skirts but no one makes a carbon fiber lip he says so im making him one using 2x2 carbon fiber twill weave. Any positive coments are welcome so enjoy. Any inquires p.m me for your needs i also do hydrodipping for wheels and valve covers ect. located in San Marcos c.a all work done on my free time at home.
Heres the Lexus IS 250 its going on!
Heres the carbon fiber skined on the base!
Heres the first coat of speacial epoxy resin with UV protection 1 or two more layers will fallow then a sand and a nice 2x2 clear coat and polish to finish it off. Love this resin! cyrstal clear UV protected.
Old Feb 7, 2014 | 04:34 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Custom Carbon fiber 2009 Lexus IS 250 lip
Finished the carbon lip not bad if you ask me
Old Feb 8, 2014 | 03:30 PM
eyecandynsx's Avatar
Looks good. I like it.
Old Feb 8, 2014 | 05:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
thanks.
Old Feb 9, 2014 | 07:04 AM
I used to do a lot of carbon work, but dont have a garage anymore, or much time. I miss it.
Old Feb 9, 2014 | 10:59 AM
wunfstgsr's Avatar
Loved
Community Favorite
nice did you use the vacuum method? and where did you get the vacuum plastic bags ext.
Old Feb 11, 2014 | 03:28 AM
I actually did all mine by hand, which was a real pain in the ***. If I was doing anymore carbon work, I definitely would have been bagging it!
Old Feb 14, 2014 | 07:06 PM
romansevo8's Avatar
So do you just over lay on the existing lip?? What the cost for something like this?? Is there any wright-ups on this?? Want to do something like this for my evo cuz CF lips are way too expensive.
Old Feb 17, 2014 | 05:57 AM
SIRX's Avatar
maybe its just me or the pictures are off but If id had payed money for that kind of work I would be pissed. just doesn't look very clean or smooth and the close ups are god awful
Old Feb 17, 2014 | 10:25 AM
wunfstgsr's Avatar
Loved
Community Favorite
Lol maybe its just you Are you looking at the pics of it finished And installed On the car or just the pics of it After applying the resin before I was done?? Cause after the wet sand and clear it was much smoother and finished As you see on the last pic of it installed in the car!
Old Feb 17, 2014 | 10:57 AM
wunfstgsr's Avatar
Loved
Community Favorite
Yea there's lots of write ups and you tube videos it cost about id say about $175-$200 in materials and takes a bit of practice and lab or. This is a skining process which is nit the conventional way most carbon pieces are made cause that is done using a vacume method to get that smooth finish but that requires a mold to set the lip in then covered in plastic and you vacume the air out while vacume sucking in the resin. Similar results can be achieved using multiple coats of resin then wet sanding using various grades of sand paper to get it smooth and flat then fallow with a coat if clear coat or polish using polishing compound. The comment above referring to it looking ugly is because for one I didn't use the vacume method and two he must be looking at the pics of it when it just got its resin coats. The pic with it installed on the car was when it was wet sanded and cleared and as you can see looks pretty good if you ask me compared to the look if his seibon hood. I did recommend to the guy another layer if clear resin for a smoother finish but he didn't want to pay for it so I did the best with what he gave me. The trick is to layer the resin lightly multiple times to work up a good thickness other wise you get a texured Feel if you don't get enough resin layered on. To get it smooth and flat use 220 grit and wet sand with a small block and work your way to 800 grit it will get nice and smooth then give it a polish or clear coat.
Old Feb 17, 2014 | 08:43 PM
romansevo8's Avatar
Nice... What exactly do I search for on youtube??? Also want to do this cuz Im on my third lip and they aint cheap lol. Also is the vacuum method any cheaper?
Old Feb 18, 2014 | 05:13 PM
wunfstgsr's Avatar
Loved
Community Favorite
Well you need more materials and a vacume pump and it requires a mold to set it in which is Why I just skipped all that. Search how to make carbon fiber parts. They sell the kits as well with the vacume and all the stuff you need on certain websites that are linked to the videos. There's a video that shows how to make your own cf hood refer to those videos and others. If your local in sd I can do it for you for a small fee but its allot of work but nothing you can't do in your garrage.
mugenboy711
Welding / Fabrication
Jun 17, 2013 10:09 PM
benson1127
Nov 7, 2007 10:13 AM
spectacle
Jan 30, 2005 06:51 AM
