1998 honda accord ex OBD 2 problem?
Old Feb 1, 2014 | 06:47 AM
92cb7sk8er's Avatar
Icon2 1998 honda accord ex OBD 2 problem?
Hey call me stupid for doing this or this question....
But my wifes are is a 1998 Honda Accord Ex 3.0 v6 "j30a1"
We went to start it last week and it would not start with out pumping the gas even then it wouldnt idle. So I brought the good old chilton out and it said that I could test the ECU using a jumper wire. I dont have an OBD 2 reader so I decied to use a paper clip. When I pluged the clip into the marked 8 and 13 port it sparked a bit and the CEL went off and will NOT come back on. I also can no longer get the car to start. I replaced the main relay and got no results. I just want to know if I made the problem worse. I'm not sure if I killed the plug, blew the CEL, or fried the ECU? Any one else ever try this and have the same problems? I was told to pull the battery so I did but its charging so I havent put it back in. I am just looking for some input from you guys.
Thanks for the help guys!
Cody
Old Feb 3, 2014 | 03:04 PM
Lost Again's Avatar
Default Re: 1998 honda accord ex OBD 2 problem?
Ouch.....most parts stores will test codes for free.
Which pins did you jump - ref pic.
What is the car doing now? Engine spins with starter, no spark....engine spins with starter but no fuel......or spins with starter but no fuel or spark?
Donny Morgan
Mar 10, 2017 08:15 PM
JDM_Mugen_CD6
Oct 2, 2016 12:35 PM
rafa357
Jul 18, 2015 07:50 PM
busdriver1191
Apr 11, 2014 06:19 AM
90CoupeTX
Apr 5, 2010 03:21 PM
