Is my head still good
Old Jan 30, 2014 | 07:27 PM
tecatown2091's Avatar
Default Is my head still good
Blew my hole in my engine a few months back and parked it . And now that I have the time and some money to fix it .im wondering if I should get a new head .how hard is it to replace a engine I know somewhat of Hondas I've just never done manual cars ..
Old Jan 30, 2014 | 07:52 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Is my head still good
Not much we can tell you from looking at it like that. Are any of the valves damaged? Are they all sitting flush with their seats?
Old Jan 31, 2014 | 05:48 PM
Shawn Wendling's Avatar
Because the head is aluminum, and if it has been excessively over heated then the could warp! Take it to a machine shop or do it your self. But you can have the head milled so mating surfaces are even. You can lay a straight edge across length of head and use a feeler gauge. I'm pretty sure the acceptable spec. Is three thousandths of an inch. If it slides through under straight edge then have it milled ! It will be better than new because it will actually raise your compression ratio and possibly increase performance. Other than that if the valve train is in tact and nothing broke you should be good. You should have performed a compression test on each cylinder. That way you can tell if valve and pistons are operating properly? Hope I helped
Old Jan 31, 2014 | 05:53 PM
Crackheadbooboo's Avatar
yeah I was gunna say you cant really tell till you clean it up does anything rattle can you shake or move anything at all or even alittle I mean your not giving us much detail
Old Jan 31, 2014 | 05:55 PM
in the first picture how did the decent size scratch get there theres no moving parts for it to hit it
Old Jan 31, 2014 | 09:21 PM
James_Woods's Avatar
its a d series, just replace the entire thing.. d15/6 heads go for like $30?
Old Jan 31, 2014 | 09:31 PM
NotARaCist's Avatar
Try $50-$100, depending on the head and how complete it is. I see no reason to replace the head though. The tools to check it for warpage are stupid cheap - I would just check it, and if it's good, roll with it. Wouldn't hurt to tear it apart and have it cleaned before putting it back on though.
Old Jan 31, 2014 | 09:38 PM
obviously, but i wouldnt sweat it.
Old Feb 1, 2014 | 04:27 AM
94EG8's Avatar
Seagull Management
If you threw a rod the head may or may not be junk, you wont know until you pull it off the block. Sometimes when the rod breaks the piston is travelling up and it just keeps going until it slams into the head.
88 EF Hatch
Jun 12, 2010 02:37 PM
bigsnorlax
May 7, 2009 11:08 AM
Hybrid96EK
May 1, 2007 07:32 PM
postalrat
Jul 10, 2005 08:05 PM
