'01 GSR codes p0170 p0172
ok, been getting these codes randomly for the past few months... more frequently as of recently
car dies at idle and wants to die when resting foot on the gas.. it also has some rough starting issues if you try and start it after it has just been shut off(see vid)
things done so far:
new plugs
new wires
new cap/rotor
new o2 sensor
any other suggestions?
might the valves need to be adjusted?
here is the vids i've taken
things done so far:
new plugs
new wires
new cap/rotor
new o2 sensor
http://www.justanswer.com/honda/0dx6...170-p0172.html
https://www.google.com/search?source...es+p0170+p0172
those are the car running rich or to lean maybe reset your ecu since you changed the o2 sensor.
i had those codes on my old audi and had to chnge the o2 sensor and reset the ecu.
its been a few years since the fuel filter has been changed... but i wouldnt think that would cause it to run rich
i never did reset the ecu.. i'll give that a try and test out the tps
LOL, a few years is way too long.
No, a bad fuel filter will not cause a rich A/F condition, but a clogged filted can have about the same symptoms as you are having and a new filter is needed and can't hurt. 94
InTheZoneAC
May 9, 2012 05:12 PM
