Suspension & Brakes Theory, alignment, spring rates....
progress CS-II Coilover Spring rate
Old Jan 30, 2014 | 08:45 AM
Freemananana's Avatar
Default progress CS-II Coilover Spring rate
Looking for some quick opinions. I read the website and I'm pretty sure I'm in the 350/350 spring rate range. I do, on occassions, drive this car to work though. Which is only 2 miles or so, but the roads aren't very smooth. Would I still be okay with 350/350 or should I step it down to 350/250?
The car is a 1989 hatchback, boosted B16A, intended purpose is drag racing. I don't care for any particular look, but I do want some decent, entree level, performance coilovers.
Thanks
http://www.progressauto.com/products.../productID/778
STREET PERFORMANCE:
These kits use 350# front and 250# rear springs. This calibration rides well on uneven road conditions if set up at a reasonable ride height around 1.0 in. to 1.5 in. less than OEM. Expect a dramatic improvement in handling capability and steering response. This is the choice for sport-tuned "daily drivers".
STREET-SPORT
These kits use 350# front and 350# rear springs. This calibration is more aggressive and transitions faster for the "sport" driver. Expect a dramatic improvement in handling capability and response, and some reduced ride quality. This is the great choice for "street and track day" multi-use vehicles, and vehicles driven hard on better (smoother) roads.
Old Jan 30, 2014 | 09:30 AM
Charlie Moua's Avatar
Default Re: progress CS-II Coilover Spring rate
350/350 is 100% fine.
my ef is only lowered by 1.5" with the csII kit.
the wife and i have taken the car out on date nights, midnight drives on curvy & bumpy roads.
wify approved.
we are considered old too.... 31.. lol
Old Jan 30, 2014 | 09:46 AM
wify approved.
Sounds perfect then. Wife approved isn't even necessary. I don't really care for the look of being low, but the performance aspect. So this should be great. Going to order a set shortly.
Old Jan 30, 2014 | 10:08 AM
mar778c's Avatar
Community Builder
Community Influencer
I run the AutoX kit on my EF 500/350. It makes the car feel solid.
I also have a 350/200 on my integra. A very nice ride. I don't race the integra.
Also, if Charlie is old then I must be ancient....46... lol.
Old Jan 30, 2014 | 10:20 AM
500/350! Hot dog! These only go up to 450/500. Would 450/350 be any better? This car doesn't see a lot of roadage. It's my daily driver...sort of. I have another car that gets 35 mpg and has A/C. So I tend to drive that more than this now days.
I'm honestly open to spring rate suggestions. I thought 350/350 would be a good start. It is for 'drag racing' mostly. So I think a higher rear would help keeping the nose down during launch. Cornering aspects are NOT nearly as important to me.
EDIT: Had to add the not portion.
Old Jan 30, 2014 | 10:44 AM
GagnarTheUnruly's Avatar
Stiffer rear rates are better for drag racing I think because they result in the chassis responding quicker to weight transfer. I'm not sure if extra compliance in the front helps anything although Progress recommends 350/500 for drag racing (with the CSIIs).
However I think for DD 350/350 is probably the best compromise. It'll be safer on the road, too. There is room for opinion on how tolerable the 350 rear rate is. Less room for opinion on the 500 rear. Certainly some people DD 500 rear but I would not want to. Particularly on a car as light as your hatch.
Old Jan 30, 2014 | 10:48 AM
Could you explain how the 500 rear rate would effect my daily driver on the street? You seem to know more than I do about this. I'm definitely up to being schooled on a subject I am just starting to tackle.
Old Jan 30, 2014 | 07:40 PM
mar778c's Avatar
Community Builder
500 in the rear is fine for drag racing but it will make the car very twitchy. In the rain, the car will be not so fun to drive.
Old Jan 31, 2014 | 02:52 AM
I'll keep that in mind.
Honestly, 350 rear compared to the 110 stock should be enough of an upgrade. My car makes less than 300 HP.
Old Feb 2, 2014 | 05:11 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
350/350 is perfect for a dd. Very comfortable. I recently upgraded the rear to 450 since I autox it a lot. On the hwy, the back end tends to have a little bounce when going overpasses.
Old Feb 3, 2014 | 08:45 AM
Could I get a couple quick opinions on 350 vs 500 for drag racing. Obviously, 500 will be better, but how much more based on the fact that I have a 2300 lb car (with me) that only makes 280 whp.
Old Feb 3, 2014 | 09:35 AM
When I was 350/350, I was having issues getting into the 13's. After upgrading the rear to 450, I ran my best time of 13.6. That's with prob 160 whp.
Old Feb 3, 2014 | 10:51 AM
Dang. Seriously? I need to work on my driving... I don't want to talk about what I run. Much better than the 19 stock the B1 put down, but nothing to write home about.
So, with 450, how was the ride? 1-10
1. Awful, eBay coilover ride or 4x4s instead of shocks.
5. Stock for being 20 years old.
10. Brand new high end luxury car. Pretty much like riding an elevator.
I am looking to be in the 3~ range. Which is rough, not good for potholes, but with a decent seat will be more than doable for regular driving.
Old Feb 3, 2014 | 04:43 PM
The 350/350 were comparable to the ride of my lexus minus all the body roll. The 450 is great but at hwy speed, you get a little bounce. My only complaint. 350/450 I would rate a 7.5-8.
Old Feb 4, 2014 | 10:04 AM
Honestly. I think I may go with 350/500 then. Can't be any worse than my Bug. I don't do a ton of highway driving. But a little bump can't be thaaaaat bad.
Metal Head
Suspension & Brakes
Dec 3, 2007 11:57 AM
dc2turbo
May 18, 2006 09:55 AM
Dyzee
May 1, 2004 05:35 PM
conesmasher
Jan 22, 2003 07:38 PM
rOby
Oct 3, 2002 12:05 PM
