Clutch issues?
Hey there guys, well these last few days ive notice that my 00 civic hx has been getting hard to start up the first time. So as i tried to start my car today its didn't even crank so i further inspected it and i noticed this near the clutch pedal. Will this be the reason it doesn't start or it might be something else?
Cool Cool Island Breezes. BOY-EE
Is your car in any gear when you try and start it? If your CMC is leaking and not allowing the clutch to fully disengage, the starter is going to have a hard time turning the car over
What do you mean hard to start, though? Like...cranking slow? Or just a lot of cranks to start?
Also just because the Neutral Safety switch is there doesn't mean it hasn't gotten flakey.
I have to have my pedal at just the right height to start mine. I need to adjust that switch but have been too lazy.
A test that you can do is turn the key to start and then push the clutch down to the floor. If it begins cranking as you depress the pedal, that switch may need adjustment.
