B16 test pipe and afr
Old Jan 29, 2014 | 02:40 PM
killerEg2's Avatar
Default B16 test pipe and afr
Hello guys i own a stock b16a del sol.Today i put a test pipe and i wanted to know if my afr will be affected. Lean or rich? Thank you
Old Jan 29, 2014 | 02:59 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B16 test pipe and afr
Your actual motor AFR's should be unaffected. Your "sniffer test" AFR's will be seriously affected.
Ya know what else will be unaffected? Your power.
Old Jan 29, 2014 | 03:51 PM
B_Swapped93's Avatar
Yup no way you'll pass any emissionos test with it on.
Ya like 8whp y0 bcuz race car op keep on being a ricer....
Old Jan 30, 2014 | 12:17 AM
Fishbone Fan's Avatar
Did you throw a CEL?
Does your state require emissions testing?
Out of curiosity, did you notice any performance or smoother gear shift changes?
Old Jan 30, 2014 | 02:23 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Smoother gear shifts? From an exhaust components?
Old Jan 30, 2014 | 01:15 PM
killerEg2's Avatar
I actually live in Europe.We have emissions test which i failed before.Thats the reason i removed it. Without it the car seems to be better after 7k rpm. Noo shifts are not affected by a cat. =]
Old Jan 30, 2014 | 02:32 PM
NotARaCist's Avatar
lol if you failed with an old cat, you're going to fail even worse with a test pipe.
Old Jan 30, 2014 | 07:48 PM
I suggest you move to China.. they obviously don't give a **** about any type of emissions.
http://latimesphoto.files.wordpress....ina-smog10.jpg
Old Jan 30, 2014 | 08:05 PM
Last year a (let's say..a non-certified) mechanic changed my timing belt, water pump, tensioner, cam seal, accessory belts, new oil + fliter, pcv valve and ripped out the cat screens all in the same day. Afterwards the car shifted much smoother and I attributed that to the lack of back pressure from gutting the cat. Is the new timing belt the reason for a smoother shift? As a side note it has deeper (IMO better) sound to the exhaust after the cat was gutted.
Old Jan 30, 2014 | 08:11 PM
NotARaCist's Avatar
Nope, doesn't work that way. The rest of the tune-up may have made your car shift better, but the gutted cat didn't cause it.
jdmisoverrated
Jan 31, 2008 07:54 AM
shn1per
Oct 7, 2005 06:55 AM
io_burn
Nov 12, 2002 07:20 AM
