96 gsr dies when given gas at normal temp
Old Jan 29, 2014 | 01:44 PM
96blk_vr's Avatar
Default 96 gsr dies when given gas at normal temp
i am looking to buy this gsr but the sell said that the car dies when it is given gas at normal operating temp. he says the car idles fine. new to honda scene kinda. any info on this problem or clues .
Old Jan 29, 2014 | 01:54 PM
fcm's Avatar
fcm
Old Fart
Default Re: 96 gsr dies when given gas at normal temp
May be a problem with the ECT [engine coolant temperature] sensor, check the spark plugs to see if engine is running rich.
The ECT sensor supplies ECU/ECM with engine temp., it will run rich when cold and then lean out as engine temp. goes up, if it does not and you are running rich symptoms will be...
Easy starting when cold.
Harder starting when warm.
Poor fuel economy.
Poor running engine, bogging and possible stalling. 94
Old Jan 29, 2014 | 02:04 PM
96blk_vr's Avatar
from what the guys says that it runs some time and when it does it idles fine and then when it reaches normal temp you give it gas and it dies.
Old Jan 30, 2014 | 12:31 AM
Tekkno's Avatar
Poor fuel economy.
My 01 GSR have these problems
Easy starting when cold. ( starts like a champ)
Harder starting when warm. (Changed starter, at least it will start now when its hot/under sun for sometime , but feels weak )
Poor fuel economy. (25 mpg average now, it used to be 30)
How should i get started to solve this problem?
Thank you!
Old Jan 30, 2014 | 01:28 AM
HondaPartsHero's Avatar
Technical Hero
Please start your own thread so it doesn't get confusing ^
OP, is the check engine light on?
Old Jan 30, 2014 | 10:13 AM
96blk_vr's Avatar
I have no idea. I am looking to buy this car. I aksed the seller if there was any codes or other symptoms that the car might be having.
KidDxbOrI
Jan 7, 2014 10:06 PM
stocker2shocker91
Nov 2, 2012 06:45 PM
team indepenents
Mar 7, 2009 04:51 AM
adler
Sep 25, 2004 09:24 AM
bossman032
11
May 28, 2003 07:44 PM
