Del sol b18b1 swap FITV
Old Jan 29, 2014 | 09:30 AM
wwbiker832's Avatar
Default Del sol b18b1 swap FITV
I recently got a new project car, its a delsol with a b18b1, it has the surging idle problem. I was looking for the FITV to clean it but there isn't one. Did previous owner change out the throttle body to something different?. I thought all b18b1's had FITV.
Old Jan 30, 2014 | 09:37 AM
wwbiker832's Avatar
Default Re: Del sol b18b1 swap FITV
anyone? do all b18b1's have a FITV or only certain years?
Old Jan 30, 2014 | 11:12 AM
kyden's Avatar
manual obd2 b series cars didn't have a FITV.
Old Feb 3, 2014 | 09:15 AM
wwbiker832's Avatar
its obd1 but the throttle body must be from an obd2 because there is no FITV. the timing was to advanced and once I adjusted it stopped the surging. however the idle is still high and I am having a hard time getting it set right. does any one have the proper calibration values to calibrate the TPS, I was told its 0.5v at closed and 5.0v at wide open
Old Feb 3, 2014 | 11:32 AM
fcm's Avatar
fcm
Old Fart
Did you clean the IACV? 94
Old Feb 3, 2014 | 04:48 PM
wwbiker832's Avatar
I replaced it with new one from autozone, checked for vacum leaks and made sure the butterflys were closing all the way. The timing was some what advanced so when I retarted it a little it stopped the surging but idle is about 1150rpm. I tryed adjusting the idle according to the service manual with no succes. Its basically turned down as low as it can be.
Rjcourg
10
Jul 21, 2013 11:07 AM
gokus-eg2
May 21, 2012 09:21 PM
schools94
28
Jul 21, 2010 07:43 PM
Green B16Sol
Aug 30, 2006 05:15 PM
B-Series Sol
Sep 3, 2002 11:56 PM
