'99 Civic EX Aluminum Oil Pan Hondabond or no?
Old Jan 28, 2014 | 08:22 AM
Brickster's Avatar
Default '99 Civic EX Aluminum Oil Pan Hondabond or no?
I'm working on a friend's '99 Civic EX with the Aluminum oil pain that is getting replaced along with a rear main seal/clutch job.
I've bought a new gasket from the dealer for it along with some Hondabond and while I've searched around for an answer as to whether to use it or not, I'm sort of confused. It seems that many of these engines have a stamped steel pan and use a different gasket than the aluminum pans and I've read about using Hondabond with them, but am confused about where to use it if at all on this pan.
Thanks!
Old Jan 28, 2014 | 08:35 AM
crazyhouse2011's Avatar
Default Re: '99 Civic EX Aluminum Oil Pan Hondabond or no?
Hello. Welcome to honda tech!
Old Jan 28, 2014 | 09:47 AM
Brickster's Avatar
Originally Posted by TomCat39
Just do the four corners where it goes from horizontal to near vertical as the FSM suggests on the block side.
To clarify, I should put some Hondabond on the block on the vertical portions only, correct? Inside or outside of the seal or both?
Old Jan 28, 2014 | 01:01 PM
HondaPartsHero's Avatar
Technical Hero
Y8 is slight different style gasket but Hondabond is used in the same place. Make sure to torque in the correct sequence and specs.
Old Jan 28, 2014 | 01:24 PM
Jimmy's Avatar
Global Moderator
So many people fail to do this properly yet wonder why their oil pan leaks... good info provided here
Old Jan 28, 2014 | 02:20 PM
Technical Hero
Sorry that picture didn't show up close enough but Hondabond goes in these locations on the Y8 where its shaded
Old Jan 28, 2014 | 03:53 PM
Brickster's Avatar
Thanks for the excellent information, guys!
One more question, am I correct in reading above that my oil pan requires Hondabond on the threads of the pan bolts?
TomCat39: Wouldn't re-torquing the bolts after a time damage the Hondabond that was applied to the threads? Assuming it was applied, of course.
Old Jan 28, 2014 | 04:47 PM
Technical Hero
According to the manual yes
Old Jan 28, 2014 | 06:08 PM
Brickster's Avatar
Thanks for the clarification!
And thanks to everyone for all the help!
I've done tons of mechanic work and have a small shop where I work on older Volvos. I've done quite a lot of wrench-turning over the years and I used to own an '81 Accord that I did all sorts of work on, although it didn't need that much.
This is what I usually work on:
Old Jan 29, 2014 | 05:14 AM
purgat0ry's Avatar
The woman or the car?
Kidding man
Enjoy what you do regardless of the car... or woman...
Old Jan 29, 2014 | 05:24 AM
Brickster's Avatar
MrTorres
Honda CR-V & Element
May 19, 2017 06:46 AM
Yeti Smasher
Honda Civic (2001 - 2005)
Mar 28, 2013 05:51 PM
j4s0n1337
Nov 24, 2011 08:31 PM
dgerej2
Jun 13, 2011 12:12 PM
Rhood
Feb 5, 2007 03:08 PM
