Suspension & Brakes Theory, alignment, spring rates....
Coilovers - Whats Up They Are Seized Up?
Old Jan 27, 2014 | 12:43 PM
Skelley1980's Avatar
Default Coilovers - Whats Up They Are Seized Up?
My coil-overs were already on the car when I purchased it. The front may be a little too low for my low pros and 18s. The tires rub the underbody on tight right turns. The spring in the back isn't resting against the top of the shock. So when I put the spanner wrench on the whole coil over spins around the base of the shock. The nuts are stuck in place. Do I need two spanners and twist different directions to crack them loose? I'd hate to put her in the shop for a damn screw.
Old Jan 27, 2014 | 01:12 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Whats Up They Are Seized Up?
A picture would be useful since not all setups are the same, but yes, on most coilover setups you need two spanners.
Old Jan 27, 2014 | 03:06 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
18's and a civic....
Old Jan 27, 2014 | 10:11 PM
Tyson's Avatar
Default Re: Coilovers - Whats Up They Are Seized Up?
lift the whole axle side up, not just the corner or left/right side.
this way the swaybar doesnt put an extra amount of pressure on the springs, making it harder to turn the perch.
Old Jan 27, 2014 | 10:49 PM
m4xwellmurd3r's Avatar
His springs arent even touching his upper mount because of all the droop.
Op yes you need two wrenches to losen up the two collars. They are tightened against each other
JasinC19
Suspension & Brakes
15
Feb 28, 2012 07:46 PM
Fnix
Apr 10, 2011 03:54 AM
Midori Green
Feb 2, 2007 02:05 PM
00CivicSleeper
21
Jun 22, 2005 12:11 AM
darkfx
Sep 17, 2002 11:20 AM
