Pgm fi to mpfi on d15b2
I was looking around on the swap and was seeing that everyone was saying you need the si mani and everything else. Is that the only manifold and other things that i can use for the conversion. Is it possible to use an intake and parts off of a y8 motor? And did the automatic civic hatch come with a sohc zc? Thank you
You can use any of the newer SOHC D-series manifolds through 2000. If going with the Y8 manifold make sure you get one with the provision for the IACV(EACV).
Thank you. I know this is off topic but i am in need of a gasket for where the oiljet used to be. The old one that was on my car has a crack and im currently leaking a little oil. I have looked everywhere but cannot seem to find one.
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
Makes it easy if you have part # when you go to dealer.
Thank you so much. I looked at the link and the picture did not show a part number for what i need. I guess at one point it was carbed and someone switched it and theres a thick figure 8 type gasket. I would say its at least 1/4 thick. I have looked everywhere and no luck.
Kdeezy95
Nov 12, 2013 04:07 PM
dudesitsjdm
Nov 17, 2010 04:46 PM
anotherstar_noz
Nov 2, 2008 06:25 PM
JDM_EK_JOE
Apr 30, 2006 04:29 PM
4g4me
Apr 28, 2003 09:32 PM
