is this an alternator problem?
Old Jan 26, 2014 | 08:06 PM
low'n slow's Avatar
Default is this an alternator problem?
i just noticed a few days ago my car started cranking really slow. my dash lights are very dim and my windows roll up and down at a slow pace (when the car is running). i had replaced my battery and alternator a few months back, could it be a bad alternator? any help is appreciated
1993 civic ex. b16a swapped
Old Jan 26, 2014 | 09:02 PM
MisereNoire's Avatar
Default Re: is this an alternator problem?
I would start by checking the main ground from the battery...see if theres any corrosion/moisture/loose bolt going on there. if it checks out, check battery terminals, then load test the battery, THEN if all that checks out, go ahead and have the alternator tested. but yeah, if things are that dim/slow when running...get that alt checked anyway, sounds like the charging system is weak.
Old Jan 26, 2014 | 09:15 PM
NotARaCist's Avatar
I never narc'd on nobody!
It could also be the belt.
Use a voltmeter and test the alternator and battery. First, do a read across the terminals with the car off. Second, do a read across the terminals with the car on. What are those two numbers?
Old Jan 26, 2014 | 09:17 PM
crazyhouse2011's Avatar
Time to clean and sand all of your ground wires. Take all 3 of them off, sand down the terminals, replace the 10 mm bolts (or at least sand them down), and sand down the areas on the chassis where the grounds rest. Works wonders on a 21 year old electrical system.
Old Jan 26, 2014 | 09:18 PM
We are looking for roughly 12.0 to 12.2 volts when off, and 14.0 to 14.4 volts when running.
raidacaipo
10
Jul 29, 2008 01:13 AM
EG6R
May 10, 2007 01:57 PM
ID_ten_T
Nov 2, 2004 11:24 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
