Suspension & Brakes Theory, alignment, spring rates....
Heim Endlinks on Stock LCA
Old Jan 26, 2014 | 08:07 AM
chillerice's Avatar
Default Heim Endlinks on Stock LCA
Sup Guys,
I'm planning on getting a ITR 2mm rear sway bar for my EJ8 this summer. I'll be using a ASR or some other credible brand subframe brace.... Any suggestions?(kinda on a budget).
My question is though. I plan to keep my factory control arms. I was looking at Function 7 end links due to the metal bushings that fit the ITR sway bar ends.
Will the endlinks bolt up to the stock LCA and if not... What other stuff do I need to have a good fit?
Old Jan 26, 2014 | 08:53 PM
1998GsRIntegra's Avatar
Default Re: Heim Endlinks on Stock LCA
Do the stock LCA's have the provision for a sway bar end link bolt? Sorry, not all that familiar with the various models of civic. If they do, then yes the spherical end links will bolt up. I'm sure Function7 wants at least a few $$$ for their end links. You could come up with the exact same thing by purchasing the female and male heim joints from a site like summitracing.com. Would probably be a little cheaper. Just a thought since you said you were on a budget. By the way, for knowing it's called a heim joint.
Old Jan 27, 2014 | 01:02 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
F7 endlinks are actually one of the cheapr endlinks. Unfortunately I am using F7 control arms as well w/ my F7 endlinks. From the look of the stock arms off a integra (with stock rear sway bay), I don't see why you couldn't use them
s13hero
May 7, 2011 03:58 PM
shotgun2224
Feb 18, 2008 10:10 PM
jdm_j03
Aug 22, 2007 01:38 PM
gritsak
Suspension & Brakes
Apr 9, 2006 07:38 PM
