Power window conversion from 00 EX to 99 Cx
Old Jan 25, 2014 | 07:48 PM
DAPhatch99's Avatar
Icon2 Power window conversion from 00 EX to 99 Cx
I got the complete doors from a 00 ex along with the floor harness. I wanted to convert my 99 cx to power windows, would i have to change my dash harness or is it just the floor harness? Should i get any relays, fuses, anything else from the ex to make the conversion a smooth, complete plug and play process?
Thanks in advance
-Brian C.
Old Jan 26, 2014 | 10:44 AM
DAPhatch99's Avatar
Default Re: Power window conversion from 00 EX to 99 Cx
bumpp.... help please!
Old Jan 26, 2014 | 12:03 PM
tony_2018's Avatar
Fish Twig
Only the floor harness.
Old Jan 26, 2014 | 12:49 PM
Marvin1985's Avatar
http://www.hondahookup.com/forums/sh...96-00-civic-DX
Old Jan 26, 2014 | 01:13 PM
tony_2018's Avatar
Fish Twig
I'll add more. The floor harness is needed and will complete the power window and power door lock conversion. There are fuses that need to be in place and I think a relay is needed on the fusebox.
Old Jan 26, 2014 | 08:28 PM
DAPhatch99's Avatar
thank you, if i'd like to also use the remote and keyless entry system from the 00 ex would i need the dash harness also?
Old Jan 26, 2014 | 08:42 PM
tony_2018's Avatar
Fish Twig
If that is the case than you just might need all of it. Its work pulling the dash but if you have the parts car next to you than go for it.
Old Jan 26, 2014 | 11:28 PM
DAPhatch99's Avatar
Yeah I figured, thanks i appreciate all the help you've been.....
Old Jan 27, 2014 | 12:43 AM
Marvin1985's Avatar
You need a relay and 3 20 amp fuses for windows/locks/mirrors. If you want keyless entry I think you need to oem radio too not sure tho
If your cars a hatch, you also need 3 wires from your stock cx or dx harness to be able to use rear wiper if equipped.
Old Jan 30, 2014 | 05:38 PM
99cxhatchback's Avatar
you can use just the floor harness. but you will need to remove the heater core and the dash for easier installation. the part of the floor harness that goes to the passenger door is literally about 1 inch from the blower motor. as for the driver side you can get to it but you have to bend up like a pretzel. ive done this swap 3 times now.
Old Mar 30, 2014 | 06:33 AM
DManInDTown's Avatar
I'm in the process of doing this swap right now. I have the floor harness out of a 99 si and the harness that goes into the passenger door has a green clip with a grommet on the outside. The old grommet had a orange clip. I'm stuck on how to get the new grommet to lock on the door. Any suggestions? Thank you.
Old Apr 4, 2014 | 05:54 PM
OP, did you every get your conversion to work? I got everything hooked up, but it's still now working. I used a multimeter and i get power to the master switch, but there is no power to the harness that plugs to the regulator
blueBB4lude
10
Oct 7, 2009 05:17 PM
iiPancho
Jun 21, 2009 05:43 PM
rayzhatch95
Mar 20, 2004 10:17 PM
