99 si/gsr swap won't start - timing?
Old Jan 24, 2014 | 06:49 PM
hmonguy918's Avatar
Default 99 si/gsr swap won't start - timing?
Here's the scenario. I drove home from work and as I hit v tech to get on the free way my car made a weird noise and it bogged out. I drove it for a few miles and it died. After it died I started it and it ran but only for a few seconds then it died. I put it in gear after it starts but it won't go. The cluster is throwing a battery light when I start it. Had to get towed home. After I got home the cat would crank but won't start. The crank is a lil faster then usual. When I pulled of the free way after it died and I started it it didn't make any knocks..the car just wwouldn't go and would flash battery light a few seconds and die. I checked oil water and fluids and its still good. No leaks no nothing and timing belt is still in tact. Do u guys know wat it could be? This is my firstt dd project. It s a 99 si with a gsr swap. It ran for three years no problem but no its dead. Pls help. Thanks guys.
Old Jan 24, 2014 | 07:07 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: timing or not
Test your alternator. You'll need a voltmeter.
Car off, test across the battery terminals. What is the reading?
Car running, test across the battery terminals. What is the reading?
Old Jan 24, 2014 | 07:27 PM
hmonguy918's Avatar
Car does not turn over but I will test with the ignition on. Thanks..
Old Jan 24, 2014 | 07:30 PM
NotARaCist's Avatar
Ignition on won't help - you need the alternator to be spinning to test it's function.
So your car tries to start, but doesn't? Do you hear the main relay engage and the fuel pump pressurize when you turn the key to ON(II)?
samples26's Avatar
Battery light could be flashing just because it is stalling out when you start it... we're you riding it hard when it happened. It kind of sounds like a air or fuel problem to me throttle could be not opening all the way or at all and it's choking it self out. Could be a sensor...not familiar with the lay out of your motor but check any air/fuel sensors for being loose or dirty and check the voltage. It's usually little things that your forget to check that are the problem I had a gti that wouldn't turn over changed out the ignition switch and starter before i found out it was the clutch safety switch on the pedal that fell off lol
Old Jan 25, 2014 | 11:23 AM
hmonguy918's Avatar
I tested the car and there's sparks firing from all wires. When I turn on the ignition, I can hear the fuel pump and it does engage but when I go to start it it won't turn over.I checked the throttle and everything is still intact. The throttle rotor is still there and in tact. I will do some more tests and get back to u guys. Thanks.
Old Jan 25, 2014 | 03:33 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
When you say it won't turn over, do you mean you only hear a click when you turn the key and the motor doesn't crank at all, or is it cranking just not firing?
If it's not cranking over at all that's usually a starter problem.
Old Mar 29, 2014 | 12:06 AM
hmonguy918's Avatar
Starter engages but it wont catch. Thinking its.my timing but if It is then why my belt is still intact but wouldn't that mean my valves would be bent and I would have to take the head off to replace the bent valves? Info pls
Old Mar 29, 2014 | 12:08 AM
hmonguy918's Avatar
Gonna open up the hood and do some more test tommrow. Maybe starting with my dizzy and wires. Excluding the plugs due to new exchange three weeks before the incident.
Old Mar 29, 2014 | 12:31 AM
P-M-B,93EXsedan's Avatar
Timing can get messed up without snapping the belt. It could be stretched or some other thing to cause it to jump a tooth and **** up your compression by having valves open at the wrong time. Under this scenario the valves would not necessarily but could possibly be bent.
I bet you're gonna have use electronics diagnosis tools and check voltages of stuff and junk like that.
Old Mar 29, 2014 | 06:10 AM
Former User's Avatar
Default Re: 99 si/gsr swap won't start - timing?
You can't test for spark if the engine doesn't crank, so you really don't know if there's spark or not.
Charge or jump the battery to whether the starter cranks the engine.
Old Mar 29, 2014 | 06:42 AM
tony_2018's Avatar
Fish Twig
Ron he stated the car does crank. Have you checked the backup fuse in the engine bay fusebox? Check main relay? Do you hear the fuel pump priming?
Old Mar 29, 2014 | 06:44 AM
tony_2018's Avatar
Fish Twig
Try again but this time put your foot on the pedal just a bit to give it a bit more air.
Old Mar 29, 2014 | 06:48 AM
I wasn't sure. "Engage" doesn't necessarily mean it turns, but you may be right.
Old Mar 29, 2014 | 07:00 AM
tony_2018's Avatar
Fish Twig
Understood, most people do get those terms mixed up.
Old Mar 29, 2014 | 08:14 AM
zerovandez's Avatar
I had a similar issue a long while ago. Its was the pgm/fi fuse in the engine bay of my ek blowing due to a grounded o2 wire.
young geezer
Jun 10, 2011 05:36 PM
swizz977
23
May 6, 2011 04:01 PM
3k9civic
10
Aug 22, 2006 02:56 PM
vtecman
53
Jul 5, 2005 09:49 AM
97H22
May 1, 2003 09:10 AM
