U-brake turned into E!-brake!
Old Jan 24, 2014 | 03:26 PM
Skelley1980's Avatar
Default U-brake turned into E!-brake!
St. Louis and much of the Midwest is in the deep of old man winters snooze. I ran out late one nite and found my e-brake had seized. I had to rev up the motor and damn near do a burn out to break it loose. So I jacked it up and was going to DIY and busted a stud(maybe my lowered suspension did, I just discovered it). So I had to put it in the garage. The garage cleaned up the brake dust and adjusted my u-brake handle. The garage suggested not using the emergency brake unless absolutely necessary (I.E. hills, parking lots, etc.). For $160 I could have figured that out for myself, had I been able to cut the stud. No tools at the old man's house. Point being....!!!!Emergency brakes like to seize up, I'm a keep some deicer with me handy. Opinions?
Old Jan 24, 2014 | 03:29 PM
B_Swapped93's Avatar
Default Re: U-brake turned into E!-brake!
what are you asking imo replace the cables they're 60 each from Honda and less at a part store. that way it won't mess up again. "U-BRAKE" pls explain
Old Jan 24, 2014 | 05:59 PM
b20bFourDoorCivicLX's Avatar
just yesterday my e-brake button fell inside i had went to a buddies he get it out also he tightened it up witch caused it to seize up and i got home with my drums smoking hot i had to get my car towed back and he loosened it back up ******* moron smh is that common for someone to tightening up e-brake
Old Jan 24, 2014 | 11:41 PM
tony_2018's Avatar
Fish Twig
Okay, problem solved BUT what is a u-brake?
Old Jan 25, 2014 | 03:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Google comes back as the caliper brakes on a bicycle for u-brake.
I was thinking maybe in the UK they call it U-brake instead of e-brake....
Now I am not so sure. :D
Old Jan 27, 2014 | 12:39 PM
U-brake......whip a U-turn brake. Only in the snow.
charlieboy88
Jan 4, 2013 07:58 AM
globy123
Aug 15, 2007 05:27 PM
thenick
Nov 12, 2002 07:50 PM
d8168055
Jul 19, 2002 09:20 PM
