68mm throttle body
Old Jan 24, 2014 | 09:36 AM
JDMequalslife's Avatar
Default 68mm throttle body
Okay just wanna know if a d16z6 manifold can be ported that big to fit a 68mm throttle body. The motor is a zc block, p29 pistons, z6 head, oversized valves, comp srpings. so its not stock. want a 66 or 68 but wanna know if i can even bore the manifold that big.
Old Jan 24, 2014 | 10:36 AM
B_Swapped93's Avatar
Default Re: 68mm throttle body
no. even the sunk2 one only allows 4mm over it's 70mm plenum, stop wasting money on that set up.
Old Jan 24, 2014 | 10:50 AM
B series guys hate so much. Its a question. Everyone can build want they want
Old Jan 24, 2014 | 11:20 AM
yes that's true but you'd have more to spend if you know power to cost ratio just buy a skunk2 manifold and get a 70mm tb problem solved.
Old Jan 24, 2014 | 12:13 PM
Im trying to avoid that manifold. My friend works there so i can get a deal but the runner ports dont even match, they are smaller then stock -_-
Old Jan 24, 2014 | 12:15 PM
I know peope have ran a ctr on the z6 manifold so ill probably end up doing that. About the cost. Ive spent about 1800 on everything, not including stuff that i did before i decided to add the pistons
Old Jan 24, 2014 | 12:17 PM
total opposite for the b-series ones.
62mm is the ctr tb bore. and your z6 plenum will be 60mm.
Old Jan 24, 2014 | 12:25 PM
Yeah skunk2 i question sometimes. Isnt the z6 56mm? I could be wrong
Civicek000
Oct 23, 2016 07:07 PM
Civicek000
Oct 20, 2016 04:37 PM
blackoutvtec845
May 11, 2010 05:49 PM
shahriar35
Jan 31, 2010 12:13 AM
JforJonathan
10
Apr 10, 2004 12:15 PM
