Both power accessory sockets not working!
I have a 2007 Honda Accord EX 4 cylinder. A few weeks ago I had both my radar detector and my iphone plugged in and charging through a dual outlet DC adapter which was plugged into my front power accessory socket. Then, suddenly it stopped working (radar powered off, phone wasn't charging). I smelled a slight burning smell coming out of my power socket. Now, nothing works when plugged in there. Also, nothing works when plugged into the second accessory socket located in the center console arm. I have checked for blown fuses marked for the accessory outlet - both under the hood and in the bottom driver side panel - everything is fine there, no blown fuses. Unless I missed a fuse to check.
Could this be an electrical problem? Could this be a problem with the socket? Why isn't the second socket working - could it be a short in the wiring?
Trying to solve this problem on my own with the help of a friend. He plugged in a voltage meter into the socket and said it was getting power. Could someone kindly provide some steps to take to solve this problem and what parts could be ordered, etc., Please help! Many many thanks!
Sounds like you're pulling too much amperage for the socket and ended up cooking some wires. Fuse should have stopped it before then but didn't.
Some things you can check:
-Check continuity to ground. You can have power all day long but, if you have no ground the circuit won't work.
-Pull the accessory panel and look for burnt wires. Replace as necessary.
user114
Feb 6, 2013 04:17 PM
wildzx
10
Jan 8, 2010 07:28 PM
Gold DA9
Jul 27, 2009 03:22 AM
idumpwitmy12gaugepump
Audio / Security / Video
May 22, 2008 07:18 PM
dean2
Oct 20, 2007 04:20 PM
